Author Topic: Water pump and thermostat leak 2019 .  (Read 27963 times)
Offline ianmb
« on: 24 September 2024, 16:57 »
Does anybody know if the later cars still have this fault ,what mileage,age does this problem occur.
Offline rowlers
  • I'm back - MK7 GTI
Re: Water pump and thermostat leak 2019 .
« Reply #1 on: 24 September 2024, 20:46 »
Still have issues AFAIK.
Offline Rudedog
« Reply #2 on: 24 September 2024, 20:46 »
Yep had mine done about two months into my ownership which would have made my car about 16 months old   and around 11k miles.  I knew it was the one thing I should look out for so as soon as I suspected a small drop in coolant (and I was getting the sweet smell after I switched off) I took it back and the dealer replaced it without really questioning it.
Offline P6GTD
« Reply #3 on: 25 September 2024, 11:04 »
MY 2019/40,000 miles
Offline Henners
« Reply #4 on: 29 September 2024, 00:13 »
Just got my water pump replaced MK7 GTI 2016 PP, £700ish
Offline Big Col
« Reply #5 on: 07 October 2024, 20:26 »
mine - 2019 - was leaking at 3yo and 25k miles.
Current - 2019 Golf GTI
Previous, 2016 Golf GTD, 2014 Leon FR, 2010 Ibiza FR, 2006 Fabia vRS , various Vauxhalls
Offline Adam T7
« Reply #6 on: 08 October 2024, 06:20 »
Spookily mine is going in this morning due to coolant level dropping slightly - suspect the usual culprit.
Offline Rudedog
« Reply #7 on: 08 October 2024, 08:39 »
My level still drops by a few mill over a couple of months so I had it tested by VW under my extended warrantee but they said it was ok and just to monitor it.
The big difference between this and the first time it happened when there was the very distinct sweet smell of coolant at switch-off around the engine bay.
Has anyone had the coolant pressure-cap become faulty and would that potentially cause a small drop in the tank level?
« Last Edit: 08 October 2024, 11:19 by Rudedog »
Offline joe6
« Reply #8 on: 08 October 2024, 09:34 »
Had a drop in coolant level that was then pressure tested. Dealer said there was evidence that the water pump had been replaced and some air in the system had eventually reached the reservoir. Topped up and no further issues.
Offline Adam T7
« Reply #9 on: 08 October 2024, 13:55 »
Mine’s been pressure tested, no drop in pressure, so just something else to keep my eye on.
Edit - forgot to add I’ve ordered a new expansion bottle cap as there was some dry coolant residue around the top of the bottle.
« Last Edit: 11 October 2024, 08:39 by Adam T7 »
