Author Topic: Water pump and thermostat leak 2019 .  (Read 28127 times)
Offline Starlet_gt
Re: Water pump and thermostat leak 2019 .
« Reply #10 on: 11 October 2024, 07:43 »
Mine went in last week due to coolant level dropping. Again, pressure tested and no issue found.
Offline GKR47
« Reply #11 on: 11 October 2024, 08:36 »
I had this problem with a slight coolant loss and after taking it back to VW a second time it turned out to be a leaking coolant overflow bottle which was replaced. Its been ok now for nearly 2000 miles.
Offline EB2019
« Reply #12 on: 16 October 2024, 19:15 »
mine is booked in for a couple of weeks time, after an initial inspection
VW authorized the warranty replacement which is a bill of £1200 (obvs, not to me but its on the paperwork).  They will probably just replace the thermostat if the pump isn't leaking or the other way round, but with warranty I'm not too fussed going forward.
if any of you are fiddling with your expansion tank bottle you could remove silica bag from the reservoir?  Did mine about a week after I picked it up.
