Author Topic: Paint flaking  (Read 9577 times)
Offline CookieMonsterGTi
Paint flaking
« on: 17 August 2024, 07:22 »
Noticed yesterday the section under the bonnet where the wipers are that the finish has started to flake off. Not sure when this started as it’s really out of eye line.
Anyone else had the same? This is on a TCR if it makes any difference… ceramic coated and safely washed.
Pure Grey GTI TCR 5 Door DSG
19" 'Reifnitz' Alloys Including DCC
Climate Windscreen
Panoramic Sunroof
90% Rear Tinted Glass
Offline willni
Re: Paint flaking
« Reply #1 on: 17 August 2024, 12:38 »
On the wiper arms or on the edge of the bonnet? One of my wiper arms is flaking, keep meaning to either paint it or replace it.
Offline madstaff
Re: Paint flaking
« Reply #2 on: 17 August 2024, 15:32 »
On the underside of the bonnet above the drivers wiper arm pivot - seen this on a Mk7 before.
Re: Paint flaking
« Reply #3 on: 17 August 2024, 16:32 »
Exactly this.
Sounds like it may be common. Do you know if anyone got support from dealers to fix at all?
Climate Windscreen
Panoramic Sunroof
Offline Rudedog
Re: Paint flaking
« Reply #4 on: 18 August 2024, 11:15 »
My passenger wiper started to discolour where the arm connects to the wiper-blade when it was only around 18 months old, I pointed this out to my dealer but it was dismissed saying I must be using the 'wrong' screen wash! I've only used VW or Quantum.  I touched up the etching marks which looked ok but in the end I replaced the passenger one when the hinge started to go white.
Now got the same on the drivers side  :sad:
The wipers and scuttle area gets a lot of abuse with liquids and full on baking sun, probably why so many go grey after a while unless you protect them.
Re: Paint flaking
« Reply #5 on: 18 August 2024, 12:40 »
This area is shaded from sun I would think and don’t think it would be affected or touched by any screen wash even if that was an issue.
In for MOT next month so will enquire then.
Climate Windscreen
Panoramic Sunroof
Offline madstaff
Re: Paint flaking
« Reply #6 on: 18 August 2024, 13:58 »
Keep us posted, intetested in to what they may say.
Offline Mikeyd1
Re: Paint flaking
« Reply #7 on: 19 August 2024, 19:22 »
Pictures please
2017 gti dsg white silver, 3door, dcc , Brescia alloys, pro Nav dvd ,dynaudio, dcc . Rear tints
Re: Paint flaking
« Reply #8 on: 19 August 2024, 22:24 »
Away from the car at moment but found this which looks the same:
https://www.reddit.com/r/Golf_R/comments/1cqgbp3/has_anyone_else_ever_have_the_paint_come_off/
Climate Windscreen
Panoramic Sunroof
Offline Adam T7
Re: Paint flaking
« Reply #9 on: 20 August 2024, 08:03 »
When I first read these posts I thought the reference to flaking was along the bonnet trailing edge, but the actual area is in such a weird place? Assume there’s no trim touching the area etc? Makes you wonder if there was a defect in the process of painting the bonnet?
I checked mine this AM, looks ok but the quality of the finish isn’t brilliant. Good luck with getting it sorted and let us know how you get on with it.
