Author Topic: I don't believe this!!!!!  (Read 933 times)
Offline AlanMK216v
« on: 22 October 2005, 21:25 »
My motor is has been overfuelling like mad ever since i've had it so i got my haynes out and found were the air/fuel mixture screw is....
BUT it isn't even there!!!!!!!!!  :shocked: :shocked: :shocked: :shocked: :shocked:
No f***ing wonder the thing dosn't run right!
The question i have is were can i get a screw from? Breakers or can i use a standard size screw and just make a screwdriver slice in the top??
Offline Haribo!
Re: I don't believe this!!!!!
« Reply #1 on: 23 October 2005, 03:04 »
go to a scrappy and look under every golfs bonnet until you find the same engine as yours and then take the screw, its free :D
Offline Gambit
« Reply #2 on: 24 October 2005, 12:55 »
are you sure your allen key is long enough to reach it? it needs to be about 5inch long to reach it!!
Offline AlanMK216v
« Reply #3 on: 24 October 2005, 18:24 »
I don't think this is the problem now gambit so i've put a new post up about the fuel tank  :lipsrsealed:
