Author Topic: Dinosaur needs advice !!  (Read 2844 times)
Offline Tornado
« on: 21 October 2005, 22:45 »
Hello
I am an old git with a 1990 8v Golf.
I am not dead yet so i want to enjoy some sounds but I don't want to cut or change anything.
Can anyone advise what are best speakers for replacing the standard items.
Kind regards
Alan :smiley:
Lower!
Offline ...joe
Re: Dinosaur needs advice !!
« Reply #1 on: 22 October 2005, 13:58 »
for the price... get some jbl's. they do 6x4 ones for the rear speakers and if you can get a set of speaker grills for your front door pockets, then you can fit some in there. upgrading the dash ones will also do but won't be a vast improvement over the originals. this can all be done with out cutting/changing anything and shouldn't take too long at all.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Bazzer
« Reply #2 on: 22 October 2005, 17:37 »
yeah, any 13cm jobs will fit in the door pocket / grille ones. I had some Alpine coaxials in there (cost me about £50 but god knows what the numbers were). They sounded ok, but if I were to do it again, I'd get some with a bit more treble response, as the location meants they're firing into you calf muscles!!
Bazzer
Offline Tornado
« Reply #3 on: 22 October 2005, 18:20 »
Thanks Guys
I will look into jbl's as my car has no speakers at back at all :sad:
Alan
Lower!
Offline Ozz
« Reply #4 on: 22 October 2005, 18:33 »
Some nice 3-way components up front would be good, mounted in the spealer holes in door cards, with the tweeters mounted in the dash. Then replace your rears and the sounds in your car will be a hell of a lot better!!
Mk2 Gti 8v
Offline Tornado
« Reply #5 on: 22 October 2005, 19:18 »
Ozz
Do you know of 3 way jobbies which will fit?
Alan
Lower!
Offline j_s
« Reply #6 on: 22 October 2005, 20:39 »
Oz, if he uses 3 way comps, where is the midbass going to sit?
Tornado you would need to mount the tweeters in your dash locations, the midrange in the doors and the midbass (most likely a 6.5" speaker) somewhere else in the door, or fabricatr the door pockets to put 6.5" in the doors, the 5.25" midrange in a fibre glass kickbuild.
Personally, I would go for the JBL suggestion that Joe says, no messing about apart from sourcing the speaker grills for the doorpockets  :smiley:
Running speaker cable to the back (if there isn't any) is easy and putting standard sized speakers in the rear locations takes 5 minutes or so.
James
Offline Tornado
« Reply #7 on: 23 October 2005, 11:29 »
Thanks for the replies . I am going to jbl the car!!
Lower!
