Author Topic: What does tour speedo go up to?  (Read 2938 times)
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
Re: What does tour speedo go up to?
« Reply #20 on: 24 October 2005, 00:42 »
Okay depending on the make of the clocks, most of the Motometer clocks had 140 on them and the VDO usually have 120 in an 8v.
One thing to bear in mind, the 120 & 160 clocks are geared to run with the red gearbox drive gear, the 140 clocks need to have a white gearbox gear, otherwise all reading including the MFA can be out.
Our 8v originally had 120 VDO clocks, at some point in it's life prior to us acquiring it they had changed the clocks for 140 items but not the drive gear, we picked the car up and it was returning 40 mpg, not the case as we all know unless drive 55 mph.
The speedo on the car is out by 3 @ 70, actual mph being 67 and then the further up you go the more it becomes wayward, 5 @ 100, actual mph 95. All of this also alters with the amount of tread on the tyres and so on.
A good 8v with no real modification should be good for 115 and you should be able to hit the rev limiter in top gear.
Offline Organisys
  • Old and Slow...
« Reply #21 on: 24 October 2005, 13:34 »
140MPH Clocks in my 1990 8v. Motometer ones. She's done an indicated 110 MPH with a few hundred rpm to go !  :smiley:
But yes I do realise that the speedo can't be trusted at these kind of speeds.  :sad:
Offline MrF16vmk3
« Reply #22 on: 25 October 2005, 00:41 »
why bother getting het up about top end speed anyhow, the closer you get to the top end of the car the further out the speedo is going to be, I.E. it says you are doing 140, in reality you are only doing 120.
There is only one way to measure the speed accurately on the cheap in a car, and that is a GPS system on something like a road angel.
Yes, gps is the only way to know for sure. But I don't think many speedos are 20mph out, mines only5-6mph out from any indicated speed from 95-145mph (139mph in reality according to gps).
Judderi
« Reply #23 on: 25 October 2005, 14:49 »
my golf had 140 clocks in when i first got it then i put 160 ones in
Yeah and your gonna need 160mph ones if you ever get that engine in!
