Author Topic: Drivers window - loose!  (Read 763 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 21 October 2005, 07:53 »
Ok, just noticed on the way into work this morning that my drivers side door window is loose, i can actually lift the back end of it up!
Is this just a case of tighten a bolt? i have no idea how the window is secured, a diagram would be graet if any one has one!
Ta
illumin
Re: Drivers window - loose!
« Reply #1 on: 21 October 2005, 10:09 »
http://www.golfgtiforum.co.uk/index.php?topic=28216.0
Not sure if this will be helpful - still haven't sorted mine................will get round to it at some point (probably when it stops moving altogether!) :grin: :grin:
« Reply #2 on: 21 October 2005, 11:07 »
there are a couple of bolts holding it to the lifter yes, take the doorcard off and have a look!  Remember to replace the door seal if its split though or water will get in.  I used some extra cheap plastic sheeting from Focus DIY, the stuff you put down when you're painting :)
Offline Deefadog
« Reply #3 on: 21 October 2005, 11:19 »
Great, hopefully it will be a few turn on the screw driver and sorted! - probabblly will not though knowing me :)
