Author Topic: Autohold v Handbake  (Read 5556 times)
Offline dilligolf
Autohold v Handbake
« on: 21 June 2023, 09:50 »
I couldn't find if this has been covered before.
I assume autohold isn't good if stationary for long periods (traffic lights etc), as autohold is no more than a break, as I see the brake lights in the rear view mirror. The engine is sending power to the wheels via the diff, the break is stopping the wheels from spinning and causing load/wear of the diff or clutch?
Cheers!
Offline Adam T7
Re: Autohold v Handbake
« Reply #1 on: 21 June 2023, 11:06 »
If you have a DSG box my understanding is that it will disengage the clutches when stationary in Drive - I could be wrong though.
Have to admit, hardly ever use Autohold, just engage neutral and use the handbrake.
Offline sjw
« Reply #2 on: 21 June 2023, 12:10 »
Cheers!
I'm pretty sure that auto-hold is the standard behaviour? I would have thought it was just a case of whether you want your DSG-equipped car to creep or not. I doubt VW would put in a feature that unnecessarily wears the clutches, diff etc and make it accessible with a single button press.
Offline Finglonga
« Reply #3 on: 21 June 2023, 13:26 »
With me, Parking Brake is used for parking only, Auto Hold for everything else. Never has issues.
Offline Rudedog
« Reply #4 on: 21 June 2023, 13:43 »
Turned off as soon as I got my car - with a DSG I can't see why I would need it. Even on steep hills I go from neutral to drive then foot off brake and immediately onto gas. Never had any roll back. Light stays off unless it is accidentally pressed.
Offline Vwjap
« Reply #5 on: 21 June 2023, 15:41 »
Never switched it off, never used the handbrake, just pull up, engine off and jump out,
Offline lessers
« Reply #6 on: 21 June 2023, 18:21 »
Me too auto hold when driving and handbrake when parking..... I only had the car 2 mins and parked up and to my disbelief, I pressed the lock car on the fob and luckily parked on a relatively flat bit of road and it started moving forward, getting faster and faster, had to chase it down the road, open the door and jump in, before it rolled into a van. My Mrs would have killed me
2019 Black golf Gti performance 245 manual box gloss black
Offline dilligolf
« Reply #7 on: 26 June 2023, 07:46 »
Thanks all.
Concensus seems to be it doesnt cause additional wear.
Will try to dig around to see if it disengages anything.
Offline DSGboy
Re: Autohold v Handbakeg
« Reply #8 on: 03 August 2023, 11:13 »
After a massive fuss in USA donkey’s years ago re Runaway Audis, you can be certain that Autohold etc has been well thought through and well engineered by VAG  for its purpose.
I struggled to get used to Autohold in my R after a Mk6 GTI - was grasping a missing handbrake  lever for a while.  But in routine driving I find Autohold works so well I have almost come to take it for granted.
A bit like you do with ACC!
Gone. Mk6 GTI DSG, 2012 ,5dr , DPB, 18’s, Leather, Dynaudio, Cruise, DAB, Auto Mirrors, Storage Pack, TPMS.
Current. Mk7.5 R DSG, 2019, 5dr, DPB,  Pretorias, Leather, Memory Seat,  Climate Screen, Rear Camera, Black Caps
Offline joe6
« Reply #9 on: 04 August 2023, 09:32 »
We have both a mk6 and mk7. I miss the autohold on the mk6 but have never forgotten to use the handbrake when stationary yet! Sometimes wonder where to put the key (stop/start button) when getting into the mk7 :smiley:
