Author Topic: New Clutch Recommendations  (Read 5021 times)
Offline jaceyboy
« on: 13 October 2022, 16:09 »
Seems like the slave cylinder is leaking inside the gearbox so makes sense to maybe change the clutch at the same time while its out.
We are running a stage 1 map and whilst we have no clutch slip can anyone recommend which is a decent make to put back in?
Thanks :shocked:
MK7 GTi
Offline Carbon VW
Re: New Clutch Recommendations
« Reply #1 on: 13 October 2022, 18:20 »
I have the Sachs SRE clutch kit installed in my gti stage 1. Little firmer than stock but a great clutch. No more slip after fitting. I also replaced the release bearing. The flywheel was in good condition so nothing done there
« Last Edit: 13 October 2022, 18:23 by Carbon VW »
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline jaceyboy
« Reply #2 on: 13 October 2022, 18:48 »
Thanks, what mileage had yours done?, can you send a link to the kit please?
MK7 GTi
Offline Carbon VW
Offline ianr8
« Reply #4 on: 13 October 2022, 19:36 »
I would avoid RTS. The twin friction set up sounds great however the one they sent me looked as though it had been manufactured at home and hand sprayed with black paint. It was fitted with the correct alignment tool and juddered from day one. Taking it apart and one of the rivets was proud and had scoured the flywheel - hence the judder.
Now I may have just been plain unlucky but I don't think so.  Instead I just fitted a new Sachs clutch and flywheel fitted
for the Golf R to my lowly but still very entertaining manual standard 220 bhp GTI. Should last for many miles.
Just my experience.
Offline Riv151288
« Reply #5 on: 13 October 2022, 22:37 »
Cant fault RTS to be honest, i gave got there single mass flywheel and organic clutch setup with there uprated slave cylinder on my mk7 gti
Pedal feels lovely and the car absolutely rips so im well chuffed with it and was a good price direct from there website
Offline jv
  • Administrator
« Reply #6 on: 13 October 2022, 23:06 »
And you joined just to say that?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Riv151288
« Reply #7 on: 14 October 2022, 04:57 »
Well no…  i joined because i love my golfs and thought I would give my opinion on a product!!! This topic just happened to be the first post that I posted on as I’ve recently had to have a clutch setup put in my mk7 gti
You stayed up late just to say that?
Offline jaceyboy
« Reply #8 on: 14 October 2022, 09:27 »
Can anyone recommend a standard clutch, does the Golf R clutch fit?
MK7 GTi
Offline Carbon VW
« Reply #9 on: 14 October 2022, 12:13 »
It will fit but is almost just as weak as the GTi one so will slip if mapped. It has slightly higher torque limits but not by much. Go aftermarket
