Author Topic: Mk6 Mdi lead issue  (Read 23567 times)
Offline Mileymk6
Mk6 Mdi lead issue
« on: 04 July 2022, 10:26 »
Hi
I have a 2010 mk6 with the rns310 DAB hi and Dynaudio
The car came with the Mdi box in the armrest but the lead has fallen apart.
Can I use any lead or does it have to be the same one as the one I have seems quite rare and expensive.
It’s the green collared lightning cable.
2010 Mk6 3Dr, Blue graphite, 18” Monzas, rns310 Dab with Dynaudio, standard apart from Stainless exhaust. Called Miley cos it’s done a lot of miles!!
Offline Mileymk6
Re: Mk6 Mdi lead issue
« Reply #1 on: 08 July 2022, 19:30 »
Bit of an update
Sourced a second hand replacement with green sleeve and identical model number and tried it today, it charges the iPhone 11 I have but says Device not recognised!
Any suggestions?
It’s a 2010 GTI with the 310 head unit I think and it’s got Dynaudio of that makes a difference
Cheers.
Offline joe6
« Reply #2 on: 10 July 2022, 12:21 »
I think there was a problem of compatibility with the mk6 mdi until 2012. Would charge but not play.
Offline Mileymk6
« Reply #3 on: 12 July 2022, 15:13 »
Right, didn’t know that. Apparently the guy I got the car off used it for his music but then again he said it worked and later I found out the connector wasn’t even attached to the wire!! Hmm!!
