Author Topic: Changing Ignition Switch  (Read 1938 times)
Offline Gambit
« on: 19 October 2005, 13:50 »
how much of a mare is this to do? is it a full steering lock/barrel removal job or is there a sneaky way around it??
its an early spec car with earlier electrics and steering column shroud.
Cheers,
Craig
Offline Agreeable Slick
  • Unit
Re: Changing Ignition Switch
« Reply #1 on: 19 October 2005, 15:03 »
here
same applies mate  :cool:
« Reply #2 on: 19 October 2005, 16:11 »
apparently if you get a small screwdriver & bend the end you can just get the screw undone without removing the ignition shroud.  Not done it myself though ;)
Offline Gambit
« Reply #3 on: 24 October 2005, 13:08 »
right i changed it on saturday and it didnt make the slightest difference to my starting probs!!
as for changing it. easiest was is
remove steering wheel
remove stalks
undo bottom universal joint below pedals
withdraw whole steering column and lock
bend screwdriver to get at screw for switch!!
if your car is pre 88 with the smaller steering wheel fitment then you can withdraw the steering lock without removing whole coulmn but if its post 88, then it has the new adapter on it and you've no hope of shifting it!!
not that bad a job to attempt
still doenst fix my prob of the car taking forever to start. turns over for ages, the seems to fire when you release the key (sometimes!). checked all earths etc but they are clean. what else can it be?
Offline Diluxe
« Reply #4 on: 12 November 2005, 21:16 »
Hey, it sounds like i've developed the same problem as you, didnt you ever get to the bottom of it?
1997 16V
Offline Gambit
« Reply #5 on: 13 November 2005, 12:30 »
aye a new set of spark plugs solved it........seriously!!
Offline Diluxe
« Reply #6 on: 13 November 2005, 18:25 »
I know you said pre88 but i've got a 89 small bumper model will i have the smaller steering wheel firmet is there a way i can tell?
the barrel seems to be in a metal body that goes around the steering column and then has one allan key on the left that clamps the two halves of the metal body together, is the steering lock?
cheers
1997 16V
Offline Gambit
« Reply #7 on: 14 November 2005, 13:05 »
aye, you'll have the later steering wheel. easiest way is to undo the universal joint at the bottom of the column and remove the column that way
Offline Diluxe
« Reply #8 on: 16 November 2005, 13:07 »
cheers for the info so far, is there anything i should note when undoing the joint bolt in the footwell?
and is the universal joint the only thing that stops the column being pulled out of the dash, if so could i not just leave the steering wheel attached and just undo the plugs on the back, or am i being doughnut  :tongue:
and i take it back i've got an F reg car it was just registered in 89 so i think it might be the same as yours.
cheers
1997 16V
Offline Gambit
« Reply #9 on: 16 November 2005, 13:37 »
only thing you need to remember about the universal joint is when refitting you need to line up the groove in the bottom of the column with the two bolt holes in the UJ otherwise the bolt wont go thru. u'll see when you get it out
not sure if you could leave the steering wheel and stalks on - easier to remove seeing as its only a bolt and 3 screws! but you defo need to undo the allen key bolt on the steering lock to remove it.
