Author Topic: Changing Ignition Switch  (Read 1939 times)
Offline Diluxe
Re: Changing Ignition Switch
« Reply #10 on: 17 November 2005, 08:52 »
is this the small steering wheel fitment, cos i've done the allen key bolt on the left side and the lock unit doesnt want to slide up, if it isnt then that explains it and i'll guess i'll have to undo the bolts at the joint :rolleyes:
http://i33.photobucket.com/albums/d96/diluxe/673a7a60.jpg
1997 16V
« Reply #11 on: 17 November 2005, 09:49 »
Thats the large spline adaptor on the end of the column, you have to remove this first or drop the column as said!
Offline Diluxe
« Reply #12 on: 17 November 2005, 10:55 »
cheers,  switch fitted all seems running fine.
it really is a 35 min job
now just need to find out why my mk3 isnt running and i'll be a happy man  :laugh: thanks all.
1997 16V
