Author Topic: DAB antenna installation  (Read 26333 times)
Offline garrym79
« on: 09 April 2022, 05:57 »
Ordered a new DAB antenna for Alpine DEH-7800DAB radio. Any advice on where to place it, seems front window passenger side is recommended.
https://www.dynamicsounds.co.uk/pioneer-an-dab1-glass-mount-dab-digital-car-radio-aerial-antenna.html
Offline theminty1
Re: DAB antenna installation
« Reply #1 on: 12 April 2022, 15:15 »
What kind of car do you have. I used a Polo dab aerial to fit to my mk5 golf. Couldn't get any luck with the stick on type
i had it on the front and a couple of different type and couldn't get it too work correctly. It depends on your location, im in Scotland , but possibly get away with it in London for example
« Last Edit: 12 April 2022, 15:18 by theminty1 »
Online joe6
« Reply #2 on: 13 April 2022, 15:42 »
If you have a mk5 or 6 it might be worth considering an oem dab/fm amplifier to replace the fm one. Need to run an extra cable from it to the dab connector on the radio though.
Offline Nino
  • Insta - F6UGA
« Reply #3 on: 31 December 2023, 19:41 »
I just ordered this to replace my OEM antenna and use the OEM wiring.
https://www.amazon.co.uk/dp/B01LXDBLI9?psc=1&ref=ppx_yo2ov_dt_b_product_details
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline theminty1
« Reply #4 on: 02 January 2024, 14:52 »
Ah interesting. I saw these when dealing with the heated rear window not working(broken wires where the cables come thro' from the main body of the car). Not a nice job to do.
Do feedback how you get on.
Offline Nino
  • Insta - F6UGA
« Reply #5 on: 07 January 2024, 19:24 »
Just to give you some feedback as requested, The hardest part was in general, removing the boot trim.
Once that was removed, the switch over of the unit was straight forward.
Once I followed the instructions and installed everything at the Radio end, it used all the exisiting OEM wiring, everything worked as it should.
Very happy with the kit.
« Last Edit: 07 January 2024, 19:27 by Nino »
Offline theminty1
« Reply #6 on: 22 January 2024, 07:11 »
Excellent well done :)
