Author Topic: Tyre vs pothole  (Read 3865 times)
Offline Fisher2022
Tyre vs pothole
« on: 28 February 2022, 11:08 »
Hi all
So I managed to hit a pot hole on Saturday evening on my front passenger side and it's split the sidewall of the tyre!!  :angry:
Question I have is should I just replace one tyre or both?  The drivers side front has 5-6mm left on it.
Or the other alternative maybe is that I put the rear wheels on the front (rears have 4-5mm) and then the new tyre with the other front rear on the rear - if you follow me?
Offline sjw
Re: Tyre vs pothole
« Reply #1 on: 28 February 2022, 11:20 »
I'd just do one, personally, and maybe put the rears on the front as you suggest.
Offline willni
Re: Tyre vs pothole
« Reply #2 on: 28 February 2022, 11:21 »
Option 2 is what I would advise - Move the rear alloys onto the front, and put the front alloys on the rear with the new tyre.
Offline Fisher2022
Re: Tyre vs pothole
« Reply #3 on: 28 February 2022, 12:38 »
Thanks guys.  Anything I should know when swapping?  Same front side to same rear side or opposite corners diagonally.  Any difference with doing either?
Offline Finglonga
Re: Tyre vs pothole
« Reply #4 on: 28 February 2022, 13:30 »
The tyres are directional so you can only do front to back on the same side. I have never rotated tyres and never has issues, it is just some people prefer to do it for the sake of it.
Offline Fisher2022
Re: Tyre vs pothole
« Reply #5 on: 28 February 2022, 14:38 »
Can I just check I'm looking at the right new tyre....
Mine state Pirelli 225/35/R19 88Y - is this a p zero tyre?  It doesn't state p zero on the tyre wall though
Offline willni
Re: Tyre vs pothole
« Reply #6 on: 28 February 2022, 14:42 »
Fisher didn't specify what tyres they were, but it is a good thing to highlight as I made that mistake before as I went to put tyre dressing on them after I had torqued them all up...
Rotating tyres helps check for issues like nails, screws etc, confirms they are wearing true with no issues to the alignment or pressure & helps to extend the life of the tyres as typically toward the end they wear faster.
It's easier to rotate them if you swap alloys out for a winter set up, otherwise it's a bit annoying especially since everyone may not have a proper trolly jack to use.
Offline willni
Re: Tyre vs pothole
« Reply #7 on: 28 February 2022, 14:46 »
They should state P Zero on them usually opposite side to the tyre specification, in my old ones case 1/3 turn counter clockwise, see below:
Offline dubber36
Re: Tyre vs pothole
« Reply #8 on: 28 February 2022, 16:32 »
Putting the rears on the front will give you an opportunity to give the insides of the wheels and arches a proper good post winter clean too.
Offline MKgti
Re: Tyre vs pothole
« Reply #9 on: 28 February 2022, 17:33 »
Where are you based? I have a used one about 7mm
I'm Bedford area
Collected and being driven....... Gti PP 5dr DSG Tornado red, tints and Brescia's.
