Author Topic: Has anyone Staged 1 there Golf MK6 GTI and what were the results?  (Read 23055 times)
Offline CYPRUSSPARTAN
Hi guys looking to go to stage 1 on my MK6 Golf GTI, probably will go with Rtech, anyone staged 1 theres? and what were the results? also would a stage 2 be better? as I was told a MK6 GTI runs better on a stage 1 map
Online Exonian
Welcome!  :smiley:
I had a mk6 GTI back in 2009 with one of the very first REVO maps for that engine. Money very well spent!
I had another a couple years later and put a Bluefin map on it just to see how different it was.
Rtech are good I’d think, they’ve been doing their thing for a while now.
Stage 1 is as much as you’d need for road use but if things are wearing out then replacing with uprated and going stage 2 will give you that little bit more.
Personally I’d stick with stage 1.
Offline Wugga
I’m also considering doing a stage 1 for my mk6 - what is actually done to get it fully stage 1 ? Also is it possible to eradicate wheel shudder when accelerating in first 1st n 2nd gear ? As noticed it a lot on my car thanks
VW BORA TDI 2004 (Black)
VW GOLF GTI 2002 (Black)
VW GOLF GT TDI 2005 (Grey)
VW GOLF GTI 2009 (Silver)
VW GOLF GTD 2018 (Black)
Online Exonian
Stage 1 is just an ECU flash.
To eliminate wheel hop you’ll need to do the bushes, not a bad idea to do them anyway if the car has done a few miles
Offline Wugga
How much roughly is having the bushes done ?
Offline codestud
I had mine done in 2016 with R-Tech, see below for the graph.  My standard BHP was measured at 220 on Shell V Power, this was boosted to 255.
However, if you are getting this done, upgrade your coil packs at the same time, I had one fail the very next day.
The other "downside" so to speak is that I now have to fill up only with Tesco Momentum or Shell V Power fuel.  I was told that filling up with standard 95 fuel would hurt the engine.
Offline codestud
Offline Wugga
what coil pack would you recommend? Would spark plugs need changing too ?
Offline codestud
I have just bought these coil packs and plugs, currently waiting for them to be delivered.
https://www.ebay.co.uk/itm/165014565071
https://www.ebay.co.uk/itm/183242597167
Offline Wugga
Please let me know how you get on ? Will you install it yourself? Or get a garage to do it ?
