Author Topic: Dogbone mounts  (Read 3678 times)
Offline oryx3dr
Dogbone mounts
« on: 03 February 2022, 09:21 »
Looking for some advice on which way I should go with dogbone mounts.
Looking at 034 upper and lower but hearing that they introduce quite a lot of vibrations which I'm not keen on so also looking at the Revo puck option. Anyone used either of these that can offer any insight?
Current - 2020 Black Golf GTI Performance Pack DSG, Sunroof, Dynaudio, Climate Windscreen, Brescia's
Sold - 2017 MK7 Oryx White 3dr GTI
Sold - 2019 Up GTI
Offline JMS
Re: Dogbone mounts
« Reply #1 on: 03 February 2022, 11:24 »
Pleased with my 034, yes there are some vibes when you pull away slowly with low revs while you pass the clutch biting point. (I wouldn’t say ‘quite a lot’)
Kids and wife have never commented if that gives an indication.
Perfectly acceptable to me as there is so much benefit (traction).
It’s less noticeable on a more aggressive start.
No difference in NVH when moving.
I’m in Derby if you want a demo.
For £50 and 30mins to fit, it’s a no brainer.
Previous Dubs now sold:
- Manual Mk7 CSG PP, stg1, RS3 bushes, 26mm RARB & a lot of carnauba.
- DSG mkV R32, black with even more carnauba
- Manual Corrado VR6, dragon green
- Manual Polo G40 - Tornado red, Jabbasport ported charger
- Mk2 Big Bumper 8v GTI, Calypso blue
Offline oryx3dr
Re: Dogbone mounts
« Reply #2 on: 03 February 2022, 13:07 »
Are you running the upper and lower or just lower?
Sold - 2019 Up GTI
Offline DCmk3
Re: Dogbone mounts
« Reply #3 on: 03 February 2022, 13:17 »
I am running the Leyo Dogbone insert, at first there was a fair bit if vibration and rattles but it calmed down after a couple weeks/months of driving. I don't even notice it anymore, no rattles or vibrations.
It has helped alleviate wheel hop when you break traction and the transient response from off and on throttle acceleration.
« Last Edit: 03 February 2022, 14:37 by DCmk3 »
2014 Mk7 GTI - Littco L500
Offline JMS
Re: Dogbone mounts
« Reply #4 on: 03 February 2022, 14:36 »
Just the lower.
Fit it, try it, if you don’t like it I’m sure you’d be able to sell it on for £30
Offline Rob_benton
Re: Dogbone mounts
« Reply #5 on: 03 February 2022, 20:08 »
I had upper and lower. Was terrible on a Dsg. Lower is just noticeable but fine
2014 gti pp dsg
Offline madstaff
Re: Dogbone mounts
« Reply #6 on: 03 February 2022, 20:21 »
Check out the seller joham_7642 on ebay, he has the 2 different types of Forge inserts for sale, £10 and £15.
Offline Dazie00
Re: Dogbone mounts
« Reply #7 on: 03 February 2022, 21:10 »
I had a revo one in my DSG  R and it was fine , going the same route again this time .
GTI PP, Leather, Pan roof, Rev Camera, Keyless , MIB2
Gone but not forgotten
GTI 5 Man
R 7 DSG stage 1
GTI 5 DSG
RS4 B7
GTI 4 1.8T
GTI 3
GTI 1 CAB
Offline oryx3dr
Re: Dogbone mounts
« Reply #8 on: 04 February 2022, 08:18 »
Went for the lower 034, hoping to fit this weekend so will update for those that might be interested themselves. I understand the NVH issue is quite subjective but I’ll try to give an honest update
Sold - 2019 Up GTI
Offline Finglonga
Re: Dogbone mounts
« Reply #9 on: 04 February 2022, 08:51 »
I have had the 034 lower on mine for 7 years and the NVH is virtually zero and no wheel hop at all.
Only thing I would say is the car must be level when fitting, as in jack up both the front wheels or you will get NVH as the drive chain is twisted when fitting.
