Author Topic: Mk8 GTD Lane assist  (Read 9272 times)
Offline daviegsxr
Mk8 GTD Lane assist
« on: 02 December 2021, 21:26 »
Can anyone help with the procedure for turning off the lane assist permanently on my mk8 gtd.
The local  dealer wont do it and I have spoken to an independent garage and he has asked I get info from someone on the forum and it would take him a lot less time and save me money.
Any help would be appreciated.
Thanks.
David.
Offline Dave1rs
Re: Mk8 GTD Lane assist
« Reply #1 on: 02 December 2021, 22:01 »
Depends where you live,you need someone local with an OBDeleven. If your in Nottingham I can do it....but if not then you need to let people know where you are.
All the info needed is on the OBDeleven forum.
« Last Edit: 02 December 2021, 22:46 by Dave1rs »
Offline daviegsxr
« Reply #2 on: 02 December 2021, 22:45 »
Sorry, should have said, I’m in Ayrshire in Scotland.
The guy at the local garage had OBDeleven, but has that I try and get info to save time.
Thanks.
David.
Offline Dave1rs
« Reply #3 on: 02 December 2021, 22:49 »
Here is the coding and process.
- Start ignition and turn off Lane Assist using button
- Pop the bonnet handle to release the bonnet (you do not need to raise the bonnet fully).
This is important otherwise the coding will not ‘write’ and you get a failed write message.
- Plug in OBDeleven dongle into one port (located underneath drivers right side trim)
- Turn ignition on (engine does not need to be running)
- Launch OBDeleven on phone
- Code as follows:
- go to A5 Driver Assistance control unit
-turn off sfd protection
- then Long coding tab
- scroll down to Configuration for lane departure warning Kl15
- Change from default ‘Activated’ to ‘Last Setting’
-Slide to write coding
- Coding accepted and default is now set to ‘Last setting’
- A few ignition starts to test and Lane Assist should now deactivated by default at ignition startup.
If he follows those steps it should work.
Offline daviegsxr
« Reply #4 on: 02 December 2021, 22:58 »
Ideal, I will get the guy at the garage to try this and let you know how it goes.
Thanks.
David.
Offline Splashalot
« Reply #5 on: 03 December 2021, 01:08 »
- Code as follows:
This forum needs a "thanks" button.
1972 Turquoise Superbug S; 1978 Miami Blue Golf GLS; 2007 Mk5 Tornado Red Golf GTI; 2017 Golf 7.5 Trendline Tungsten Silver 1.4ltr 110TSi with DAP; 2018 Tornado Red GTI with DAP.  All MT.  Current: 2021 Mini Cooper SE, British racing green.
Offline JoeGTI
« Reply #6 on: 03 December 2021, 09:01 »
Where's the OBDEleven forum? I am expecting a dongle in the post in the next day or two!
Offline fredgroves
« Reply #7 on: 03 December 2021, 09:10 »
https://forum.obdeleven.com/board/377/mk8
Offline JoeGTI
« Reply #8 on: 03 December 2021, 09:28 »
Excellent, thanks Fred.
Offline valentino
« Reply #9 on: 05 December 2021, 12:33 »
Do you think doing this would affect the warranty in any way?
