Author Topic: Coil Packs 1.8t 99  (Read 1957 times)
Offline G7i turbo
Coil Packs 1.8t 99
« on: 17 October 2005, 13:23 »
Previously posted regarding the replacement of my MAF sensor (for the second time in 5 weeks!). Initially thought this had solved the problem, HOWEVER! on a run from Leic to Birmingham yesterday, the car decided to run like a bag of sh1te. Sluggish, felt like it was mis firing and not running on all cylinders.
Having tried 2 brand new Mafs, could this now lead to the coilpacks being the cause? Any idea on cost, easy to do? (Im not great under the bonnet!). Also the poss of recall??
Cheers once again people
Offline G7i turbo
Re: Coil Packs 1.8t 99
« Reply #1 on: 17 October 2005, 14:02 »
Just spoken to VW, they say that they do carry out replacement coilpack work under 'recall' only for cars reg'd 2001 onwards as they said this is when they first started having the problem
Not amused
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 17 October 2005, 14:08 »
They only do recall work on 2001+ cars because the earlier cars had rock solid coil packs. It wasn't until they changed them in 2001 that they started having problems.
Since yours is an AGU its unlikely to be a coilpack fault (mine have done 80,000 miles without missing a beat)
Have you had it on the diagnostics machine yet ? or know anyone with vagcom ?
Offline G7i turbo
« Reply #3 on: 17 October 2005, 14:31 »
Dont know anyone with VAGcom, im in leicester if anyone does know where i can go? What else do you think it could possibly be?
Offline R32_T
« Reply #4 on: 17 October 2005, 19:31 »
where abouts in Leics you from?
2001 20V Turbo        1997 VR6 Highline
"Granny shifting not double clutching like you should"
Offline G7i turbo
« Reply #5 on: 18 October 2005, 12:22 »
Im Wigston end of leicester
Offline G7i turbo
« Reply #6 on: 18 October 2005, 16:52 »
Quick update, Just back from VW specialists, had it on VAGcom and no faults showing whatsoever! now im really p1ssed off. Got it booked in 2moro morning for anti roll bar bush replacement so there gonna go over it at the same time and check every other possibilty not detected on the diagnostics.  :cry:
Offline G7i turbo
« Reply #7 on: 18 October 2005, 18:56 »
Cheers for that speedo, fingers crossed it'll be running ok 2moro night when i pick it up. Will keep you all posted.
Offline G7i turbo
« Reply #8 on: 19 October 2005, 17:37 »
Just a quick update, got car back this afternoon, driving perfect, Diagnostics/ Vagcom didnt throw anything up but whilst changing front anti roll bar bushes, all pipes/hoses were checked to engine and one was slightly unseated (not much use as im not sure which one!) poss causing air induction/leak. Since sorting, it drives spot on.
Soz cant be more accurate
