Author Topic: diesel leak  (Read 1815 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
diesel leak
« on: 14 March 2021, 17:29 »
hi there just noticed this morning there was a puddle of fuel on the garage floor roughly were the passenger seat is any ideas
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline mossy69
Re: diesel leak
« Reply #1 on: 14 March 2021, 17:59 »
sorry the rear seat , it also had a new fuel pump and fuel pump module fitted last September any ideas  :cry: :sad:
Offline madstaff
Re: diesel leak
« Reply #2 on: 14 March 2021, 18:16 »
Sounds like either the lift pump/sender unit has been fitted incorrectly, the feed or return pipe has come off, or there's a leak from the fuel lines or tank itself maybe?
Not sure if this applies to a MK7, but on a MK6.
If you remove the rear seat base and remove the fuel pump/sender unit access panel you may be able to see the problem.
