Author Topic: Is this MDI cable compatible with MK 7?  (Read 4015 times)
Offline dfm
« on: 07 February 2021, 08:54 »
Only thing my new to me car didn't come with is the female usb lead I had on my mark 6 which enables you to plug a flash drive in.
I've found one on ebay for a fiver with the description - AUDI VW Music Interface MDI MMI AMI to USB Cable Data Sync Charging Adapter UK
Is this the right one? Cheers.
https://www.ebay.co.uk/itm/AUDI-VW-Music-Interface-MDI-MMI-AMI-to-USB-Cable-Data-Sync-Charging-Adapter-UK/303807512656?hash=item46bc56c050:g:YMYAAOSwPzVf1I4H
Offline mcmaddy
Re: Is this MDI cable compatible with MK 7?
« Reply #1 on: 07 February 2021, 11:17 »
If this is for a mk7 you don't use the old style cable like on the Mk6. Mk7 only has usb ports.
Offline dfm
« Reply #2 on: 07 February 2021, 12:00 »
Where are the ports? The car came with two cables for connecting phones so I think a cable is needed. Will have another around the car now before I order. thanks.
Offline Watts
« Reply #3 on: 07 February 2021, 12:07 »
My MK7 had a socket the cable linked to in the OP's post in the cubby in front of the gear stick. I think those with Nav Pro had USBs, mine didn't (standard nav).
Previously:
Offline Guzzle
« Reply #4 on: 07 February 2021, 12:14 »
I believe if you had a MIB1 generation unit then it uses the MDI cable interface. All sorts of different cables do different things depending on the colour of the collar.
MIB2 units come with a USB socket as standard in the chubby behind the gearstick and the MDI is done away with.
MIB1 = cars built before Week 22 2015
MIB2 = cars built week 22 2015 onwards.
7.5 GTD
Offline baka
« Reply #5 on: 07 February 2021, 17:32 »
yup, I got a cable identical to that for my 2015 so I could charge my phone. Though is you have the 'phone box' option there's a USB in the armrest.
Offline dfm
« Reply #6 on: 07 February 2021, 17:50 »
Thanks all. I'm calling the dealer tomorrow about something else so I'll see if they have a spare lying around they can send me plus a fuse to fix the cigarette lighter.
