Author Topic: Are these lights bi xenon?  (Read 4899 times)
Offline dfm
« on: 25 January 2021, 19:24 »
As per the title. Car has winter pack. Thanks
Offline fredgroves
Re: Are these lights bi xenon?
« Reply #1 on: 25 January 2021, 19:54 »
Doesn't have the washers, suggests not.
Is it a UK car? In Ireland on a mk7 they didn't have xenon. Some Irish cars have been brought into Britain for resale.
Offline dfm
« Reply #2 on: 25 January 2021, 19:59 »
Thanks Fred. It's an approved used from a dealer in England.
Offline Guzzle
« Reply #3 on: 25 January 2021, 20:04 »
It does have the washers if you look closely.  :nerd:
I think they probably are bi-xenon, as far as I know the imported GTi's I've seen that don't have bi-xenons don't have the red stripe through. Bit like this
7.5 GTD
Offline fredgroves
« Reply #4 on: 25 January 2021, 20:10 »
The only real certain way to tell is if you can see the build sticker in the boot and decode the build codes.
Offline wantmygti
« Reply #5 on: 25 January 2021, 20:24 »
I’ll bow to your greater wisdom but they look like halogens to me and I can’t see any washers!
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Online Watts
« Reply #6 on: 25 January 2021, 21:10 »
There were some imported from Malta that didn't have zenons.
Previously:
Offline Fabio Bignose
« Reply #7 on: 25 January 2021, 21:52 »
Yes, they are bi xenon
Mk7.5 GTD. DCC, Keyless, Dynaudio, Tech pack, Alarm, Isaac Blue
Mk7 GTD. Xenons, 18", Climate Control, Keyless, Alarm, ( all optional in Ireland...! ) Dynaudio, DCC,
CSG.
Mk6 GTD. Alarm, CSG.
Offline Rudedog
« Reply #8 on: 25 January 2021, 21:58 »
Looks a bit odd... where is the indicator strip?
I can't see the washers.. they should be a rectangle just below the lights, are we saying that that large circle is the washer?
« Last Edit: 25 January 2021, 22:01 by Rudedog »
Offline SRGTD
« Reply #9 on: 25 January 2021, 22:29 »
The circular cover is the towing hook cover.
The car in the picture that was posted by the OP in the first post for whatever reason isn’t showing now. That picture showed the front end of a mk7 Golf GTI with xenon headlamps with the ‘U’ shaped DRL’s, continuation of the red grille stripe into the headlamp units and the headlamp washer cover below the headlamps. The headlamps on that car were like this one;
The picture posted by @Guzzle in reply #3 in this discussion thread is a non UK spec mk7 GTI with halogen headlamps, no headlamp washers, and no red stripe through the headlamp unit.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
