Author Topic: 1st Golf arriving Friday 😀🚘  (Read 12260 times)
College
Re: 1st Golf arriving Friday 😀🚘
« Reply #20 on: 17 January 2021, 21:05 »
Thanks Fred, that’s great news 👍🏼
Offline skippy
« Reply #21 on: 17 January 2021, 22:29 »
Enjoy your new car when it arrives College. Mine is a 69 plate in Isaac. They are fantastic cars (as we know). Only thing is we can't really drive them at the moment!  :sad:
MK7.5 2020, Isaac Blue, standard spec
Gone but certainly not forgotten Candy White Scirocco 2.0 TSI
Offline Norwich7point5
« Reply #22 on: 18 January 2021, 11:12 »
Nice! I understand the excitement levels when I picked mine up. I couldn't sleep for days in the run up to collection day!!
Here's mine; it's very similar!
2017 mk7.5 Indium Grey Metallic GTI - 3 door - Manual - Art Velours - Brescia 19s - No fog lights!
College
« Reply #23 on: 18 January 2021, 11:36 »
The Brescias look great, can you use any alloy cleaner on them? I understand they’re diamond cut? Does this limit what I can use on them? Excuse my ignorance if any of this is wrong 😑
« Reply #24 on: 18 January 2021, 11:43 »
I'd never use any type of wheel cleaner on them; it's too harsh.
I took all the wheels off mine and washed and polished them and put several coats of Poorboys wax on them. I just wash them with the same water I wash the car with now.
They come up great every time.
Offline Guzzle
« Reply #25 on: 18 January 2021, 12:08 »
Yes Brescia's are diamond cut. I never use anything more than car shampoo and warm water on mine, and I ensure I rinse them thoroughly with clean water.
I'm not really into detailing so you'll probably get better advice elsewhere about cleaning, but one thing you really don't want to do with diamond cut wheels is damage them. If any moisture gets under the lacquer you'll eventually end up with a marbling effect known as white worm.
7.5 GTD
College
« Reply #26 on: 18 January 2021, 12:59 »
Yes I’ve seen on here the dreaded “white worm” mentioned, I’m sure a harsh alloy cleaner would eventually creep under the lacquer, so will just use normal car wash on them thanks.
Offline SRGTD
« Reply #27 on: 18 January 2021, 13:48 »
@College; if clean your wheels every couple of weeks or more frequently and they’re ‘wearing’ some decent protection (e.g. a couple of coats of wax or sealant with good durability, a specific ceramic wheel sealant) you shouldn’t ever need to use a dedicated wheel cleaner. If using wax or sealant, then I’d recommend reapplying it every 3 - 6 months, or sooner if it no longer provides adequate protection.
If you do use a wheel cleaner, ensure it’s ph neutral and never ever use an acid based cleaner or anything harsh on diamond cut alloys as it can quickly degrade the lacquer coating on the wheels, and the polished metal surface will quite soon become dull and gradually take on an appearance similar to white worm corrosion. Be aware that the majority of the many hand car wash places use strong / harsh cleaning products to remove dirt quickly - time is money to them, so strong cleaning products = more cars cleaned = more ££££’s. Therefore, avoid the hand wash places if you value the appearance of your wheels......and your car’s paintwork.
Also, I’d recommend inspecting your wheels thoroughly for damage the sooner of fortnightly or each time you clean it. if there’s and stone chip damage to the lacquered surface, then repair the damage with a clear lacquer paint pen a.s.a.p to stop water ingress under the lacquer in the area of the stone chip.
« Last Edit: 18 January 2021, 14:06 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline ar899
« Reply #28 on: 18 January 2021, 14:21 »
College - congrats on your new purchase. How does used car buying work at the mo? I'm assuming you couldn't have a test drive? Were you able to view it?
Offline Adam T7
« Reply #29 on: 18 January 2021, 15:39 »
Mines virtually identical to yours with the exception of Parker vs. Brescia wheels - same Diamond Cut finish though.
As above comment, mine are only washed with a snow foam, shampoo and a sponge. I have used Dragons Breath (the smell is out of this world) - ph neutral wheel cleaner but don’t bother anymore as I wash them pretty regularly.
