Author Topic: What have you done to your mk8 today?  (Read 787386 times)
Offline Carlosfandango
Re: What have you done to your mk8 today?
« Reply #960 on: 09 January 2025, 08:10 »
I’ll get some pics later today, on first impressions yours does look packed correctly, although the upper foam does look slightly distorted perhaps?! does the shape of the lower foam on yours match the contours of the boot floor? And is the jack fully wound in??
« Last Edit: 09 January 2025, 10:57 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline fredgroves
« Reply #961 on: 09 January 2025, 16:10 »
It should fit... my mk8 has a (factory) spare and the HK sub and the boot floor goes down ok
Offline Gt!clubsp0rt
« Reply #962 on: 09 January 2025, 18:42 »
Yes maybe the top cover foam is out of shape and causing this?
The lower foam seems to match the boot floor contour and the jack is definitely fully wound in....
Thank you the replies so far :-)
Golf 8 GTI Clubsport (2024) - Oryx White / Black Roof, DCC, Estorils, Pan Roof, Heated Seats, Reverse Cam
Golf GTI history:
8 DSG (2021) - reflex silver
7.5 DSG (2019) - 5 door isaac blue
Mk5 DSG (2008) - 3 door steel grey - currently have
Mk4 1.8T (2003) - 5 door grey anthracite
Mk3 8v (1998) - 3 door canyon red
Mk2 8v (1992) - 5 door oak green
Mk2 8v (1989) - 3 door helios blue
Mk2 8v (1988) - 3 door helios blue
« Reply #963 on: 09 January 2025, 20:41 »
I just had a look at the kit on my 8.5, I didn’t pull the whole thing out as the lower foam is clipped to the floor through the strap, it looks packed the same as yours, but I did find when I put the kit back together that the floor was sitting a bit high on that side, I pushed down on the floor and felt the foam push together, the floor was then as good as flush on both sides, but is SLIGHTLY fouling on the kit, I never have the floor in the lower position so don’t know if it was like it before I messed with it or not?! Barley noticeable though, and I would never have noticed anything had I not have been checking for it.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #964 on: 09 January 2025, 21:31 »
Thank you for the pics - really appreciated!
I found the stud in the floor pan, had to push it through the boot carpet to make it appear. I just need to get the plastic nut, which yours has, that screws onto the stud in the floor pan. This will make the base of the foam tighter to the boot floor on mine I would think and improve/solve the fouling issue. I've took some pics of the stud below.
I will let you know how I get on once I've sourced the nut!
Thanks again for your help :-)
Golf GTI history:
« Reply #965 on: 11 January 2025, 00:35 »
Good work.the fact it was sat on top of that stud was probably 99% of the issue.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline fin45cs
« Reply #966 on: 12 January 2025, 15:55 »
Afternoon all, a quick question. Looking at space saver wheel in the link on this thread for the new Gti clubby on order. Does it fit ok in the wheel well with the sub in there. If so is the sub easy enough to move to fit wheel?
Thanks for any advice.
Offline fredgroves
« Reply #967 on: 12 January 2025, 20:38 »
I have a spare and HK. The sub comes out really easily to get the wheel out.
Offline fin45cs
« Reply #968 on: 12 January 2025, 21:06 »
Cheers fredgroves. i will go order one!!
« Reply #969 on: 12 January 2025, 22:37 »
I’m unclear if you are referring to the eBay link on the previous page in this thread or not? If you are I’d be unsure as to whether the factory sub will fit correctly in that wheel!? Being an after market wheel and not OEM, it may be that the inner profile of the pressed steel may not allow the sub to fit snugly, I’ve no idea if there’d be a problem or not, but the shape does look a bit different to me.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
