Author Topic: Passenger mirror not returning to normal position after reversing  (Read 4104 times)
Offline joet
Hi,
I've a 2013 GTI PP that's I've had from new and it's been a paragon of reliability (and fun!)
Just recently however the passenger door mirror has stopped returning to the normal position after  dipping when I reverse. I've tried everything I can think of but to no avail. I can move it back manually using the mirror control, so it can't be the motor in the mirror housing.
Anyone else seen this? Any ideas what it could be?
Thanks
Offline Carbon VW
Have you changed key fobs or batteries by any chance?
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline joet
No, haven't done that for months
Offline joet
So I tried my spare key which I haven't used for months and lo and behold it's now working. So a bit of a headscrather. But at least it's working. Thanks
Offline itavaltalainen
So it goes down by itself in reverse but it's not coming back up again?
Assume you've driving over ~10mph as it won't move back up below that speed?
Offline joet
Yes, driving over that speed but it wasn't going back. But using the spare key seems to have fixed it now
Offline Carbon VW
Your welcome !!change the battery in the other fob. Set the limits again in the infotainment to reset the memory and see how you go
Offline joet
Will do! Thanks again
Need to teach positions again in that case
