Golf mk7
Jimble
PP or CS discs and pads on a standard spec Mk7?
Topic: PP or CS discs and pads on a standard spec Mk7? (Read 5687 times)
LOK
01 September 2020, 14:56 »
As above. i recently picked up a Mk 7 GTI (non PP) and it feels to me like the brakes are somewhat lacking in grunt. The intial bite is fantastc but they don't inspire much confidence thereafter and when you are flying they just don't feel up to the job. I've always owned lightweight sports cars and/or cars with serious brakes so fancy doing something to improve mine. The Golf feels like a heavy car which needs some good stopping power. So my question is are the PP discs bigger and would I need to swap out the existing calipers to fit the PP/CS discs (I suspect yes but wanted to check if anyone on here knows first). It also messes with my OCD that the current discs have slightly corroded hubs which clash with my immaculate new Belvedere wheels so they have to go!
p3asa
Forum addict
Re: PP or CS discs and pads on a standard spec Mk7?
01 September 2020, 15:12 »
Paint your hubs. It seems to be a common problem
HIS:
R 5dr DSG Lapiz: Tech Pack: Keyless: 90% Tints: Pretorias: Rear View Camera
HERS:
GTI 5dr Manual DBP: Parking Pack: Car-Net App: 90% Privacy Glass. Ordered 05-12-15. Delivered 03-03-16
DONATED TO SON:
GTD 5dr Manual White: Nav Pro: Dynaudio: Winter Pack: Sport & Sound Pack: Rear View Camera: Park Assist. Ordered 19-02-14. Delivered: 07-06-14
golfdave
Here all the time
01 September 2020, 15:26 »
PP/CCS/R al use 340mm discs & 60mm single piston sliding fist callipers, on the front & bigger vented discs on the rear
Your GTI (non-PP) will have 312mm discs with 57mm piston callipers on the front, & non-vented on the rear..
best upgrade is to swap calipers & disc on front for Audi TT-S 340mm setup with uses 4pot ATE calipers..
https://www.killerbrakes.com/product/golf-5-6-7-gti-4pot-brake-kit-upgrade-tarox-f2000-brake-discs-tarox-strada-brake-pads-new/
they do sell the calipers on their own..
Or get the Porsche Macan 4 pot Brembo which are really made for 345mm discs
https://www.killerbrakes.com/product/mqb-porsche-macan-brembo-4pot-dba-slotted-discs-brake-kit-new/
All of my "How to" guides:-
http://www.golfgtiforum.co.uk/index.php?topic=285982.0
LOK
01 September 2020, 15:46 »
Thanks fellas. So if I wanted to keep it OEM and stick to standard GTI equipment i've need to swp the discs and calipers? Assume the two piece 340mm are the same as regular with the exception of being two piece?
fredgroves
Serious forum addict
Professional Um Bongo drinker
01 September 2020, 15:50 »
Have a read of this:
http://www.golfgtiforum.co.uk/index.php?topic=286774.0
Golf mk7
Jimble
