Author Topic: OBD11 and 20 plate gti performance  (Read 6342 times)
Offline Dre1973
Re: OBD11 and 20 plate gti performance
« Reply #10 on: 10 March 2020, 18:15 »
Can't you adjust the washers so that they don't spray over the bonnet?
No it's the power at which they spray. I've disabled them now so all good.
Offline mistac
« Reply #11 on: 10 March 2020, 21:01 »
[/quote]
With Carista? If  so, what option is that?
GTI 7.5 Performance 5dr DSG Tornado Red - completely standard spec as - it comes out of the tin as they say
Offline Dre1973
« Reply #12 on: 10 March 2020, 21:38 »
[/quote]
I used obd11. Does Carista give you the option for long coding?
Offline Talk-torque
« Reply #13 on: 11 March 2020, 07:16 »
Carista allows you to lengthen the time you need to pull the screen washer stalk to fire the headlight washers. Maximum is 2.5 seconds, which is what I set mine to. You also have the option to change the number of screen wash pulls between headlight washes. I set mine to every pull so that the headlight washers are available, without any confusion, for checking, or MOT. 2.5 seconds is a long time, so easy to avoid setting the headlight washers of in normal screen wash usage.
Roger.
Offline Dre1973
« Reply #14 on: 11 March 2020, 09:46 »
Same as obd11 by sounds of it then. You have all them option as well.
Offline Goat_on_a_bike
« Reply #15 on: 11 March 2020, 09:59 »
Carista did mine. Changed it to pull the stalk for 2.5 seconds. What’s crappy about Carista? Did all the mods I needed for £16.
If that’s in response to my earlier post, I was being sarcastic  :smiley:
Can you Confirm yours is one of the later models with dynamic light  assist fitted?
It is. Carista worked very well and the months “free” use was plenty. The app seems to be kept up to date. If you check out the beta stuff available, it includes extra choices for the digital dash.
What extra choices are there for the digital dash? I’ve got a Carista but the free month is up, didn’t go Beta but might delve back in if there’s cool stuff there!
Offline fredgroves
« Reply #16 on: 11 March 2020, 10:43 »
Colour would be my guess - you can toggle the AID into GTE/GTI/R/GTD or Arteon colours sets.
Offline Talk-torque
« Reply #17 on: 11 March 2020, 19:00 »
I didn’t study the options too much, so can’t remember, but it didn’t persuade me to go beta. Someone in a car mag said that the guy who signed off white needles on white gauge markings should be fired. I’d love red needles for my digi-dash!
Roger.
Offline Vwjap
« Reply #18 on: 11 March 2020, 19:31 »
see I’ve been thinking about that, and was wondering if vcp maybe able to maybe change the colour in the AID map, if the AID map is actually downloadable then redesigned and re uploaded again, but I’ve looked and can’t find anything in the long codings or adaptions,
