Author Topic: OBD11 and 20 plate gti performance  (Read 6337 times)
Offline Dre1973
« on: 07 March 2020, 21:06 »
VW has just swapped my gti due to an ongoing fault. Obviously the new car has all the end of line features.  In my old car which was a 68 plate I could turn off the headlight washers as I hated it when it would spray water all over the bonnet. The new 20 plate car has the active full beam assist and when I try and turn the headlight washer off in the obd apps it says not available.
Has anybody managed to turn it off or has vw blocked this due to the active headlight?
Offline mcmaddy
Re: OBD11 and 20 plate gti performance
« Reply #1 on: 07 March 2020, 21:24 »
You need to use the long coding instead of apps. Apps are crap anyway.
Offline mistac
« Reply #2 on: 07 March 2020, 21:26 »
I hope you can as I want to do that on my gti when I get it. I will only have the crappy Carista though  :smiley:
GTI 7.5 Performance 5dr DSG Tornado Red - completely standard spec as - it comes out of the tin as they say
Offline Dre1973
« Reply #3 on: 07 March 2020, 21:28 »
Cheers I'll look into this.
Offline mistac
« Reply #4 on: 07 March 2020, 21:33 »
I thought I read on another thread it could be done on the later gti’s even with the likes of carista? I hope so as only going to get carista!
Offline Talk-torque
« Reply #5 on: 08 March 2020, 07:20 »
Carista did mine. Changed it to pull the stalk for 2.5 seconds. What’s crappy about Carista? Did all the mods I needed for £16.
Roger.
Offline Dre1973
« Reply #6 on: 08 March 2020, 09:04 »
I'm gonna try mine again today but not using the apps
Offline mistac
« Reply #7 on: 08 March 2020, 10:08 »
If that’s in response to my earlier post, I was being sarcastic  :smiley:
Can you Confirm yours is one of the later models with dynamic light  assist fitted?
Offline Talk-torque
« Reply #8 on: 08 March 2020, 10:18 »
It is. Carista worked very well and the months “free” use was plenty. The app seems to be kept up to date. If you check out the beta stuff available, it includes extra choices for the digital dash.
Roger.
Offline ar899
« Reply #9 on: 08 March 2020, 12:55 »
Can't you adjust the washers so that they don't spray over the bonnet?
