Author Topic: Will DSG pull away in 2nd gear  (Read 5000 times)
Offline Pretzel
« on: 19 February 2020, 18:58 »
I test drove a Mercedes C200 (petrol) yesterday with a 9 speed auto gearbox, quite liked the way it would select 2nd gear to pull away if on a flat surface.
Does the 7 speed Golf DSG do the same?
Offline Watts
Re: Will DSG pull away in 2nd gear
« Reply #1 on: 19 February 2020, 19:47 »
No idea but interested, I had an auto SAAB with Snow mode which pulled away in second. Never used it though :rolleyes:
Previously:
Offline dubber36
« Reply #2 on: 19 February 2020, 19:56 »
I'm pretty sure it won't. You can't even manually select 2nd gear when stationary.
I could in my Amarok with it's torque convertor auto box. 1st was really low and at a certain set of traffic lights on a hill, as it had no auto hold, it would creep if I didn't have my foot on the brake. To save the person behind staring at my brake lights, I could have selected neutral and used the handbrake, but selecting 2nd gear would mean it would hold without creeping.
Offline Sootchucker
« Reply #3 on: 20 February 2020, 08:44 »
Not sure I understand why it matters in an Auto ? In mine which is the older povey 6 speed DSG, it jumps into second gear at about 2 mph and much quicker than I can select anyway.
Offline dean5125
« Reply #4 on: 20 February 2020, 09:49 »
Have to agree, why does it matter?
If you want that much control over the gear you are in maybe look at buying a manual instead!! :wink:
2019 (68) GTI PERFORMANCE DSG - new baby
2016 (66) GOLF R DSG - gone but definitely not forgotten
Offline Finglonga
« Reply #5 on: 20 February 2020, 10:27 »
First gear is specifically designed to pull away with the least amount of wear and tear so why would they engineer something to cause the opposite?
Offline fredgroves
« Reply #6 on: 20 February 2020, 10:33 »
Maybe with 9 cogs it only uses 1 for uphill starts? 1st is probably really really short.
That does sound like over engineering though, solving a problem that didn't need solving.
And as others say, its an auto box, the driver shouldn't really care what gear is selected at all, the car makes the choices.
Offline Lordie
« Reply #7 on: 23 February 2020, 14:00 »
The OP may be wondering how easy it is to drive in snow conditions. It's easier to get moving from stationary pulling away in 2nd gear instead of 1st in snow
Offline Jim_mk7.5
« Reply #8 on: 23 February 2020, 18:50 »
Unless you come to a complete stop, mine doesn’t normally go into 1st. Noticed that particularly today using the ACC on the M25 in road works traffic. Even creeping along at 1-2mph it was staying in 2nd.
NOW - 330e M Sport
Offline Watts
« Reply #9 on: 23 February 2020, 20:06 »
On the M25 Jim? Are you planning a surprise visit to give my car a run over with your DA?? :whistle: :laugh:
Previously:
