Author Topic: brake discs  (Read 9630 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
Re: brake discs
« Reply #30 on: 22 February 2020, 13:44 »
padgid  brembo and dura tec mate  :angry:
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline mcmaddy
Re: brake discs
« Reply #31 on: 22 February 2020, 13:50 »
Pagid and Brembo aren't cheap parts so it does suggest as others have said that something else is wrong somewhere.
Offline golfdave
Re: brake discs
« Reply #32 on: 22 February 2020, 16:39 »
I recon that the caliper is dragging ...wrong grease on the slider pins ….I had that happen on my Mk7...to front & back...seemed ok for first 2,000miles, then they started to stick more...
Offline mossy69
Re: brake discs
« Reply #33 on: 01 March 2020, 11:04 »
hi just an update had the car in at swift motor sport Newcastle had the car fully checked nothing wrong with the car they said that the back of the pads and slider pins had copper grease on them which cause a problem with the abs unit ,,, renewed the discs and pads with genuine vw , and re greased the slider pins with lithium grease as vw recommends ...fingers crossed ,, waiting for refund from the previous garage
Offline golfdave
Re: brake discs
« Reply #34 on: 01 March 2020, 12:47 »
Copper grease will NOT cause a problem with the ABS unless it gets onto the ABS reluctor ring itself....I have used it may times on VAG cars & never had any problems...
However I have had problems with copper grease going "hard" over time due to salt, heat etc...so I use special high temp grey lithium grease made by Loctite...similar to VW "hot bolt paste"...
The slider pins on the front VW calipers now have a plastic/or rubber bush on one pin..these will "absorb" grease & swell & stick the pin solid in the hole...Been there done that....you have to use the recommended TRW "PFG-110" grease...
Long gone are the days when you could just use copper grease on all the slider pins etc...
I did a post here on this problem:-
https://www.golfmk7.com/forums/index.php?threads/vw-golf-mk7-estate-gt-spec-tungsten-silver-1-4tsi.326479/page-5#post-6767297
Offline mossy69
Re: brake discs
« Reply #35 on: 01 March 2020, 15:18 »
thanks for that interesting stuff      .. still confused hope its sorted now fingers crossed
