Author Topic: 235 on Brescia?  (Read 12707 times)
Offline clubsport
235 on Brescia?
« on: 04 November 2019, 15:49 »
Does anyone have practical experience of running a 235/35 19 tyre on a Brescia wheel, compared to the standard 225/35/19 factory fitment?
Thanks!
Offline sjw
Re: 235 on Brescia?
« Reply #1 on: 05 November 2019, 09:12 »
Would also like to know!
Offline Catnapper
Re: 235 on Brescia?
« Reply #2 on: 05 November 2019, 10:25 »
Why???
MK7.5 Indium Grey 19" Brescia Alloys
Offline SRGTD
Re: 235 on Brescia?
« Reply #3 on: 05 November 2019, 11:51 »
No practical experience, but a 235/35 will have slightly higher sidewalls than a 225/35, so you may experience more sidewall flex during cornering. You’d also need to inform your insurer as changing to a tyre size that’s different to the original factory spec tyres is considered to be a modification.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline jv
  • Administrator
Re: 235 on Brescia?
« Reply #4 on: 05 November 2019, 12:11 »
Not sure I would be able to feel 3mm or so sidewall height difference
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline sjw
Re: 235 on Brescia?
« Reply #5 on: 05 November 2019, 13:34 »
Why???
Greater surface contact with the road, availability, ...appearance?
Offline rjwojcik
Re: 235 on Brescia?
« Reply #6 on: 05 November 2019, 14:17 »
Upsizing was common when I had my BMW, 215s to 225s on the front and 245s to 255s on the rear.  Benefits as above.
Current:
2018 RS4  - Navarra Blue / Black
Gone:
2016 A6 BiTDI - Midnight Blue / Black
2016 Golf GTD with a "lot" of toys
2016 M3 CP - Mineral Grey / Black
2009 135i - Le Mans Blue / Black
Offline clubsport
Re: 235 on Brescia?
« Reply #7 on: 05 November 2019, 14:41 »
Thank you for the response up to now, I would be grateful to hear from anyone who has actually run the 235 tyre  on Brescia alloys.
Any issues such as rubbing lock etc.....?
Cheers.
Offline CS#303
Re: 235 on Brescia?
« Reply #8 on: 05 November 2019, 16:05 »
I've done it a few weeks ago.
I put the wider ones on the rear, and will do the fronts when the original 225 Pirelli tyres wear out.
235s are the width you get on the R and with Pretoria wheels, no fitment issues, rubbing or any other real difference.
Also because of that I consider them a standard size, not a modification.
I also did this slight width increase on my Corrado back in the day, going from 195 to 205.
I don't think there will be a noticeable difference in grip or handling as the change is very small. Certainly it is far beyond my driving skills or habits to discern.
The reason I did it was for a that little bit more rim protection, it doesn't hurt that I like the look too. ;-)
Check the pictures, but please excuse the dirt!
Offline clubsport
Re: 235 on Brescia?
« Reply #9 on: 05 November 2019, 17:45 »
Thanks for the response and pictures.
They look a good fit on the rims, I am also looking for the extra rim protection the 235 offers as the main reason to fit them.
