Author Topic: drivers window not auto opening.  (Read 3729 times)
Offline Gulfstream11
« on: 02 July 2018, 12:09 »
Afternoon all.
My driver side window has stopped opening on auto,(one touch). It will close but not open, I have to hold it down.
I tried the window reset method. Hold down for 5 secs then hold up for 5 secs but no change. I have OBD11,is there any coding
I could try.
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline JamesR27
Re: drivers window not auto opening.
« Reply #1 on: 02 July 2018, 22:01 »
Hi Alan, seems to be a common fault with the switch
https://www.golfmk7.com/forums/showthread.php?t=31633
Sounds like you have tried the below
https://youtu.be/37dnXOQS5pU
But could be worth trying to lubricate as it’s really dry at the minute.
Mk 8.5 Clubsport Pure White, Queenstown, DCC.
MK 7.5 R Pure White, Pretoria Silver, DCC, Rear Camera.
Gone - MK 7 GTI Carbon Grey, Rear Camera, Service Pack.
Gone - MK 6 GTI  Reflex Silver, Monza Shadows, RCD 510, Rear Camera, Bluetooth, Tyre Pressure Sensor, Xenons Convenience pack, Service Pack :)
Gone - MK 5 GTI Reflex Silver, Monza II 18's, Luxury Pack, Mulitchanger
Offline fredgroves
« Reply #2 on: 03 July 2018, 07:20 »
My last GTD did this. You could reset it with the holding the button trick and it would be fine for a little while, then go wrong again.
I did discover it was probably a faulty switch, but could never persuade the dealership to actually fix it - they just did the same reset. I could have pushed harder I guess but I wasn't about to keep running back to them for something so trivial, so gave up!
« Reply #3 on: 03 July 2018, 10:15 »
Thanks fellas. The window seal does seem a bit dry so will try lubricating. Out of warranty last month so next time I'm at the Indy he'll sort it.
Offline Mike J
« Reply #4 on: 03 July 2018, 10:32 »
When I had this problem it usually happened following a passenger operating (fiddling with) the control button.
These days, unless my passengers are VW savy I tell them to ask me if they want the window open.
Same with carrying other drivers who insist on slamming my doors as if its a Ford, I tell them this is a VW and then demonstrate the correct closing technique (stlumff).
Not keyless sorry.
Offline Briggs
« Reply #5 on: 06 September 2018, 17:18 »
Hello just thought I would share this with you hope it helps
My neighbor had problem with windows not moving up or down when opening or closing he said that it used to work until garage changed door from an accident.Well I had a look and windows all work but drivers window not on one touch .So I did a reset on window but this did not change anything so thinking it could be the switch we’re going to seek professional help but we found on the on board computer there’s a factory reset for windows operating we pressed reset and now he is all back to normal happy chap.
In short try reset window
Then reset factory settings for open and closing windows
« Reply #6 on: 07 September 2018, 12:35 »
Thank-you.
Will try it as soon as I return home.
