Author Topic: Alloys : Will They Fit?  (Read 8370 times)
Offline rjwojcik
« on: 24 June 2018, 17:59 »
Guys
Looking at a set of 18 x 8 .5, ET50s.  Any managed to fit a set on a Mk7, standard suspension setup.
If so, what tyre setup did you go for?
TIA
Current:
2018 RS4  - Navarra Blue / Black
Gone:
2016 A6 BiTDI - Midnight Blue / Black
2016 Golf GTD with a "lot" of toys
2016 M3 CP - Mineral Grey / Black
2009 135i - Le Mans Blue / Black
Re: Alloys : Will They Fit?
« Reply #1 on: 24 June 2018, 19:28 »
They’ll fit in that size.
Tyres will ideally need to be 235’s or they’ll look a bit stretched.
Offline rjwojcik
« Reply #2 on: 24 June 2018, 21:58 »
Thanks
Was thinking 255/35R18s for the tyres.
According to my calcs, I'll have 11.5mm less clearance on the inside and they'll stick out 13.5mm more.
Current:
Gone:
Offline SRGTD
« Reply #3 on: 24 June 2018, 22:54 »
Thanks
A 255 section tyre is just over 10 inches wide.
Presumably your calculations are based just on the wheel width, so when you factor in the extra width that the tyres will add - approx 38-40mm to the overall width on an 8.5j wheel (so and extra 19/20mm on the inside face and 19/20mm on the outside face of the wheel), you’ll actually have 30.5/31.5mm less clearance on the inside and they’ll stick out 32.5/33.5mm more. Could that mean your tyres extend beyond the wheel arch?
IMO, and as Exonian has suggested, 235 section tyres would be better.
« Last Edit: 24 June 2018, 22:58 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline BobbyT
« Reply #4 on: 25 June 2018, 01:04 »
235 or 245 on an 8.5. 235 will have a small amount of stretch, I've run this set up and it was fine but 245 would be perfect. 255 would be too much imho
Offline Jeff Wood
« Reply #5 on: 25 June 2018, 02:14 »
I'd stick to 8" width and 225/40's, (et40 or 45).
It's a hatchback remember not a muscle car :grin:
2018 Golf GTI. 3 Door. DSG. Tornado Red.
Eibach Pro Kit. OZ Hyper GT HLT Wheels. (18x8, ET50).
Forge 11mm spacers on rear wheels. 5mm on fronts.
Offline rjwojcik
« Reply #6 on: 25 June 2018, 08:06 »
Cheers guys, might look at an 8" solution then.  Not really keen on streched tyres, I'm not that young.
Current:
Gone:
Offline Mike J
« Reply #7 on: 25 June 2018, 08:54 »
When I was speking my new car I also considered fitting different wheels and tyres.
However, the dealer pointed out that ff the wheels and tyres were not those specifically recommended by the manufacturer in the handbook they would almost certainly affect the vehicle insurance, especially if the car was involved in an accident.
This advice resulted in a financial loss to the dealer as I choose a lower spec. car.
Having been a Court witness for an insurance company I have seen firsthand how a specialist solicitor can completely destroy the driver of an overly modified car that had been involved in a collision.
Offline SRGTD
« Reply #8 on: 25 June 2018, 09:49 »
That’s why it’s important any modifications are declared to the insurance company.
I’ve changed the wheels on my car and I declared this to my insurer. I can access my policy details on line via the insurer’s web site and can see that the modification is noted on my policy, so there’s evidence I’ve declared the modification and my insurer has accepted it.
Offline rjwojcik
« Reply #9 on: 25 June 2018, 10:58 »
I always declare my mods,  so no worries in that dept.
Current:
Gone:
