Author Topic: VCDS Coding - Warranty and other issues?  (Read 3870 times)
Offline JeffPoe
« on: 02 April 2018, 21:01 »
Hi,
Are there any potential warranty issues with changing coding settings in VCDS?
Things like stopping the headlight washers etc
I presume there are. But then, is this just things the dealer can change and will if you ask/pay them?
Its not a remap per se?!?
Offline Vwjap
Re: VCDS Coding - Warranty and other issues?
« Reply #1 on: 02 April 2018, 22:31 »
Presumably they can’t refuse warranty work if the programming has nothing to do with the faulty part, but I read somewhere that when they plug the car in to Germany it tells it if it’s had programming or a remap
Offline wantmygti
« Reply #2 on: 02 April 2018, 22:46 »
I’m not convinced on the warranty issue. Mine just had a service and none of the tweaks were mentioned, the only changes I made were to turn off the pedal box and turn off audible locking.
Most of the changes just change the parameters in which certain components come on or off. I can’t thibk of anything that actually changes any component or stresses it any harder.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline mcmaddy
« Reply #3 on: 02 April 2018, 23:23 »
If you turn the headlight washers off it would now presumably fail it's mot but an issue for warranty.
« Last Edit: 03 April 2018, 18:34 by mcmaddy »
Offline itavaltalainen
« Reply #4 on: 03 April 2018, 18:08 »
With headlight washers you can set long delay time. Had no issue getting past MOT man when set to 2 seconds delay.
Offline mcmaddy
« Reply #5 on: 03 April 2018, 18:35 »
Delay shouldn't be a problem as you say but disabling it will mean a fail as technically it's inoperative.
Offline Finglonga
« Reply #6 on: 03 April 2018, 20:24 »
Just about to say the same, also raised their frequency up to 10 sprays between activation.
Had mods done on mine since new and never had anyone query them, actually had a tech ask how to do the teardrop wipe on the front wipers.
Offline clubsport
« Reply #7 on: 03 April 2018, 21:00 »
I re-enable the headlight wash and stop/start before the Mot test, it takes a few minutes.
I imagine many on here never see an Mot test with a lease car?
Offline Finglonga
« Reply #8 on: 07 April 2018, 19:56 »
Stop/Start isn't tested, mine has been deactivated for 3 years now. Headlight washers are on a 2 second delay, easier than deactivating just in case you need them. :wink:
Offline mcmaddy
« Reply #9 on: 08 April 2018, 09:42 »
Headlight washers actually make your headlights worse unless you've got a wiper to get rid of mess. Plus they make a mess of the front end of your car too  :whistle:
