Author Topic: Swirl marks from dealers  (Read 5981 times)
Offline DarrenW
« on: 25 March 2018, 23:09 »
Has anyone else had swirl marks inflicted on their car by dealers? They’ve only washed mine twice but it looked awful under the sun today. Shameful at only 5 months old.
And on that note can anyone recommend a dual action polisher? I’ve never needed one in the past but lesson learned the hard way that VW dealers can’t wash cars properly!
Offline Booth11
Re: Swirl marks from dealers
« Reply #1 on: 25 March 2018, 23:26 »
Unfortunately very common. The only way to prevent dealers inflicting swirl marks on your car is to instruct them never to wash it.  And get some Do Not Wash hangers like these.
Recommendations for DA polishers. Can’t go wrong with a DAS6 Pro to start out with. Takes both full size pads and spot psds so very versatile. http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/das-6-pro-dual-action-polisher/prod_673.html
Look at one of the complete kits.
Also see Detailing section on here.
http://www.golfgtiforum.co.uk/index.php?topic=280786.0
http://www.golfgtiforum.co.uk/index.php?topic=277767.msg2539078#msg2539078
http://www.golfgtiforum.co.uk/index.php?topic=276899.msg2534721#msg2534721
« Last Edit: 25 March 2018, 23:28 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline MjrSharpe
« Reply #2 on: 26 March 2018, 10:00 »
The DAS above is great and will definitely do the job. In terms of polish, I recently used the Sonax Profline Perfect Finish. I found it broke down readily with just a few passes, but was enough to deal with any light swirls. It also left a great gloss and the residue wiped away easily.
2016 GTI - Tornado Red, M52 remap, DTUK Pedal box, dv+, racingline turbo elbow, forge turbo muffler delete, racingline springs, racingline stage 2 BBK, novus 0.1 wheels, injen induction kit ,st rear anti roll bar, TT short shift, 034 motorsports dogbone upper / lower inserts, sachs organic clutch, custom stainless steel exhaust, res delete, leyo bezels, oettinger rear spoiler, maxton splitter, golf r rear lights
Offline davyk31
« Reply #3 on: 26 March 2018, 10:44 »
I have bought a DAS6 Pro a few months ago but haven’t even used it yet.
Need some instruction on how to use. Which videos or tutorials are best to watch for a quickie bit of guidance.
Mk 7.5 GTi Indium Grey with 19" Brescias
Offline Sootchucker
« Reply #4 on: 26 March 2018, 11:56 »
Rebecca, where do you get these from as I can't seem them on their website shop ?
Offline Finglonga
« Reply #5 on: 26 March 2018, 12:16 »
Mine are always under strict instructions not to wash the car and I make sure I actually see them write it on the job sheet.
Offline Booth11
« Reply #6 on: 26 March 2018, 12:57 »
No they don’t sell them.  But you can get similar online.
http://carboncollective.com/product/do-not-wash-pvc-hook/
https://www.ebay.co.uk/p/Carbon-Collective-Do-Not-Wash-Hanger-PVC-Hook-Hanging-Car-Interior-Garage-Sign/592723638
https://www.autobritedirect.co.uk/index.php/ad-mirror-hanger-2pack.html
Make sure you instruct the dealer not to wash the car too, get it marked and highlighted on the dealer worksheet, then use the hangers.  Before hangers used to just write on a big piece of cardboard and stick it across front seats.
« Last Edit: 26 March 2018, 13:00 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Watts
« Reply #7 on: 26 March 2018, 14:31 »
I'm in a similar position barring the fact that I haven't bought one yet :whistle: But it is very high on the to do list :laugh:
I've been watching junkman on youtube, he does tend to repeat things a lot but he does keep it simple and is very encouraging. Only obstacle so far has been that he said not to polish outside - I've no choice on that.
Previously:
Offline dubber36
« Reply #8 on: 26 March 2018, 15:24 »
Problems with polishing outside are few. Obviously avoid direct sunlight. Make sure the section you are about to work on is dust free. It's not as easy to see your results outside either. I like to turn the garage lights off and use an LED light shone from different angles to inspect progress.
Offline Watts
« Reply #9 on: 26 March 2018, 15:29 »
Thanks :smiley:
Previously:
