Author Topic: mines runnin ruff too  (Read 3628 times)
Offline round
« on: 26 October 2003, 19:07 »
ive got a mk1 gti it was runnin fine then it jst cut out and ever since thn its hard to start and wen it does start it sounds like its runnin fine thn itll jst cut out !
ive changed the fuel pump ,cleaned the fuel filter and chekt all the jet lines i dont think its a fuel problem ! someone said it could be the inlet manifold ! could it be ? if so how do i chek it ? or if u have any suggestions as to wot it might be ! n e help is appreciated
cheers  :)
golfvr6
Re:mines runnin ruff too
« Reply #1 on: 26 October 2003, 19:18 »
When it cuts out, check for a spark.
Offline round
« Reply #2 on: 27 October 2003, 11:37 »
how do i do that ? that might sound thick ! but its jst somtimes it starts straight away which would suggest the coil is ok ! i forgot to mention 1 other thing that the fuel tank becomes realy pressurised wen its ran 4 a bit if u take the fuel cap off theres loads of pressure ! any 1 live in the northants area who is good wit mk1s com and av a look if u sort it ill pay ya cos im stumpd
cheers  :)
Offline Nostrils
« Reply #3 on: 27 October 2003, 12:23 »
If you've got a non-standard fuel filler cap, it may be causing your problem. If the tank's getting pressurised it'll stop the fuel flowing - try an original cap.
I had an old Morris Minor - took me ages to suss what was happening and it was due to a non-vented after market filler cap.
Offline round
« Reply #4 on: 27 October 2003, 14:10 »
tried that cos it does the same thing without the cap on this being the biggest vent hole ever ! but cheers 4 the suggestion open to any as like i say im stumpd
Blue MK2
« Reply #5 on: 27 October 2003, 16:18 »
To check for spark....
1* Get a spark plug and connect it to a lead in your engine
2* Step back and hold the rubber end of the lead.
3* Keep the spark plug a few mm away from the head.
4* Get someone to start the engine and see if there is a spark.
5* Do this trick with the rest of the leads but be very carful.
The spark should jump from the spark plug to the metal work on the engine.
If there is no spark check your distrubutor, leads and change you spark plugs.
Offline Maltloaf
« Reply #6 on: 27 October 2003, 18:17 »
I have encountered something simular on various cars.
Each time I have come across it, it has been the fuel pump relay. Has this been changed?
See if you can hear the fuel pump when it cuts out.
Offline shunta
« Reply #7 on: 27 October 2003, 20:45 »
On some MK1's there is a fuel filter inside the tank. This gets clogged with sh!t and makes the car run ruff if at all. It will then occasionally start fine straight after. The best way to get round this is to take off the fuel line at the engine end and blow down the line with a small compressor (oh take the fuel cap off first...).
If the filter is clogged you should here the pressure build up followed by a release of pressure and bubbles in the petrol. What you have just done is "remove" the filter. It will float around inside your tank but shouldn't cause you anymore probs.  Make sure you have an inline filter on your fuel line and you should have lots of happy motoring ahead!
Hope this helps!
golfvr6
« Reply #8 on: 28 October 2003, 00:01 »
If the fuel tank is pressurised then check the breather hoses as they are probably blocked.
Offline round
« Reply #9 on: 28 October 2003, 11:30 »
again mite sound thick but how do i do that ! i took the one of the filler neck and blew down it and it isnt blocked ! are there any more ? do these cars hav a pump relay ? if so which relay is it ?
Cheers 4 all yor help ppl ! :)
