Author Topic: Brake Pad Noise  (Read 2559 times)
Offline naxcars
Brake Pad Noise
« on: 01 February 2018, 21:31 »
Thinking of taking my month old Golf to the deealers.
I've noticed that when the car is driven slowly and I apply the brakes I can hear the brake pads applying against the discs.  I can only hear this when driving slow - but driving faster with engine noise ect I don't tend to hear the noise.  Could this be a binding pad, sticking piston?  Problems with the pads?
2014 Golf GTI Performance Pack: Nav & Rear Parking Camera, DTUK FRS+
Offline CocoPops
Re: Brake Pad Noise
« Reply #1 on: 01 February 2018, 21:43 »
I’d say normal.
The pads do run close to disc to dissipate water.
There is a VCDS setting to disable it if required.
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline Guzzle
Re: Brake Pad Noise
« Reply #2 on: 01 February 2018, 21:44 »
Mine is the first car i've had with an electronic handbrake, and I hear noises from brakes applying and releasing far more than on any other car i've had.
To be honest, I've put it down to a characteristic of the car. There are no warning lights, and the car doesn't appear to be detrimentally affected when stopping or when pulling away. My Dad's Land Rover also has an electronic handbrake and makes similar noises. I'll monitor it but i'm not overly concerned.
7.5 GTD
Offline naxcars
Re: Brake Pad Noise
« Reply #3 on: 01 February 2018, 21:46 »
I’d say normal.
I've never really noticed it and I'm compared it to my other Golf  :sad: What does the VCDs setting do?
« Last Edit: 01 February 2018, 21:52 by naxcars »
Offline GTI_Ant
Re: Brake Pad Noise
« Reply #4 on: 01 February 2018, 22:07 »
In this weather you get a sheen (patina) of ferrous oxide (rust) on the discs after the car has been standing overnight which makes a lot of noise until it gets removed by the pads.  I notice it all the time.
GTi Clubsport DCC winter pack rear camera
Previous:
7.5R 3dr DSG DPB Prets Dynaudio
MK7 GTI PP Tungsten Silver Manual Nav Dynaudio Winter Pack Park Assist
Offline naxcars
Re: Brake Pad Noise
« Reply #5 on: 01 February 2018, 22:33 »
I've covered 100 miles today and still have the noise as I've described at the end of the day and the car hasn't sat.
Offline Vwjap
Re: Brake Pad Noise
« Reply #6 on: 01 February 2018, 23:02 »
I’d say normal.
brake drying, it holds the pads on to get rid of water while driving, normally set to active from factory (well it is in mine)
Offline I wanted a GTi
Re: Brake Pad Noise
« Reply #7 on: 02 February 2018, 11:54 »
You should have bought a GTD, you would never hear it :whistle:
Offline naxcars
Re: Brake Pad Noise
« Reply #8 on: 02 February 2018, 16:07 »
 :grin:
Offline Finglonga
Re: Brake Pad Noise
« Reply #9 on: 02 February 2018, 21:06 »
If the brakes are binding you would smell it and the culprit disc would be hot as hell after a few miles. They are noisy for the first few miles even after 4 years but clear after a few stops.
