Author Topic: Uprated rear anti roll bar  (Read 12133 times)
Offline MjrSharpe
« on: 22 January 2018, 16:59 »
Hello all. I'm considering getting an uprated rear anti roll bar from ST suspensions for my car. I was wondering if anyone has one of these, or one from another brand, and what their opinion was of it? Thanks, Craig
2016 GTI - Tornado Red, M52 remap, DTUK Pedal box, dv+, racingline turbo elbow, forge turbo muffler delete, racingline springs, racingline stage 2 BBK, novus 0.1 wheels, injen induction kit ,st rear anti roll bar, TT short shift, 034 motorsports dogbone upper / lower inserts, sachs organic clutch, custom stainless steel exhaust, res delete, leyo bezels, oettinger rear spoiler, maxton splitter, golf r rear lights
Offline mkviken
Re: Uprated rear anti roll bar
« Reply #1 on: 22 January 2018, 20:16 »
I had a white line adjustable rear ARB on my mk6 and it was great
Also had the bump steer kit and castor adjusting lower wishbone mounts
Golf GTI 7.5 230 white silver
Offline DubmanSam
« Reply #2 on: 23 January 2018, 08:29 »
I have the ST Suspension RARB and its definitely worth it, only £130 at Awesome GTI and a breeze to fit. Car is a lot more pointable and flat in corners
« Last Edit: 23 January 2018, 10:41 by DubmanSam »
2016 MK7 Golf GTI PP Solid White, Eibach Pro-Kit, Forge Intake Pipe, CTS Turbo Inlet, Pipercross Filter, Rear Wiper Delete, 10mm Spacers Front, 15mm Spacers Rear, VCDS tweaks, ST Suspension RARB, 034 Motorsport Engine Mounts, Centre Resonator Delete, REVO Turbo Muffler Delete, Sachs Performance Clutch, S3 Short Shifter, Clutch Bump Stop, Clutch Delay Valve Removed
Offline MjrSharpe
« Reply #3 on: 23 January 2018, 10:08 »
Thanks for the replies. I think it seems good value at the price. Hopefully get one soon :)
Offline 7MAT
« Reply #4 on: 23 January 2018, 14:31 »
Ordered the thicker Clubsport S anti roll bar before Xmas, not fitted it yet but was quite reasonable at £88.
MK7.5 Golf GTI Performance, 3 door, Issac Blue, DCC, Manual. Racingline Stage 1 OEM+, Remus Exhaust system, Sache Performance Clutch.
Offline naxcars
« Reply #5 on: 23 January 2018, 16:23 »
Any part numbers for this? Is it a dealer part?
2014 Golf GTI Performance Pack: Nav & Rear Parking Camera, DTUK FRS+
Offline scanesare
  • GTI Clubsport
« Reply #6 on: 23 January 2018, 16:51 »
Did you happen to measure the diameter of that by any chance? Would like to see how it compares with the CS one and some aftermarket options.
ARB's are usually the best vfm suspension mod in FWD cars, the equivalent of a stage 1 remap for the chassis  :wink:
I have no particular complaints with my CS but I would imagine it shares the same rarb with the standard GTI so for £88 I could easily try the CSS option if it stands somewhere between stock and aftermarket options which I'd imagine are thicker.
Offline 7MAT
« Reply #7 on: 23 January 2018, 17:22 »
5Q0511305BA
Yep order straight from the dealer or buy online, a few on eBay for around £106 inc delivery.
Offline 7MAT
« Reply #8 on: 23 January 2018, 17:30 »
ARB's are usually the best vfm suspension mod in FWD cars, the equivalent of a stage 1 remap for the chassis  :wink: and
My understanding is that the CS shares the same ARB as the GTI Performance in the U.K.
Both ARBs are hollow, with the CCS being the same size externally but with 3.6mm thicker tubing.
Offline Watts
« Reply #9 on: 23 January 2018, 17:32 »
You may find an earlier thread useful - http://www.golfgtiforum.co.uk/index.php?topic=279388.0
Previously:
