Author Topic: GTi Mk7.5 Engine noise  (Read 9053 times)
Offline davyk31
« on: 29 November 2017, 07:17 »
I’m finding the engine a bit noisier than I expected, almost a dull diesel like noise when accelerating. I do like smooth quiet power.
I know there is fake noise when in sport mode but does it also operate in other modes or are the noises I’m hearing all natural ?
Mk 7.5 GTi Indium Grey with 19" Brescias
Offline TwoSheds
Re: GTi Mk7.5 Engine noise
« Reply #1 on: 29 November 2017, 07:38 »
The Soundaktor works in other driving modes other than Sport mode.
Try ‘Individual’ driving mode then select ‘ Interior Engine Sound’.
You can then select ‘Normal’ for less input or ‘Eco’ for even less input.
If it is this noise, still bugging you, then you can switch it off entirely with VCDS/OBD11 or physically unplug the unit itself.
Offline Wide
« Reply #2 on: 29 November 2017, 07:48 »
Is it not the exhaust that you here?. It is pretty loud  :smiley:
Sound like mine?
https://www.youtube.com/edit?o=U&video_id=zA8hylNFpp4
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline Jim_mk7.5
« Reply #3 on: 29 November 2017, 07:50 »
Maybe you've bought the wrong car.. Perhaps a GTE would have been better?
NOW - 330e M Sport
Offline davyk31
« Reply #4 on: 29 November 2017, 10:44 »
Where is the unit to unplug?
No I haven’t bought the wrong car, it’s just I don’t expect it to be as noisy as my previous GTD. perhaps I am expecting too much and it’s a minor irritation that if I can fix I will.
Offline scanesare
  • GTI Clubsport
« Reply #5 on: 29 November 2017, 11:00 »
Try to identify if it is the stupid Soundaktor first. Sounds as if the engine is stressing too much even at moderate throttle applications and more like an annoying rattle/vibration than an actual engine sound. Choose Individual and set Engine Sound to Eco, floor it, set Engine Sound to Sport, repeat, compare. Very easy to get rid of if that's the issue.
Offline I wanted a GTi
« Reply #6 on: 29 November 2017, 11:04 »
Here you go https://youtu.be/kf5RJY9Kx68
Offline fredgroves
« Reply #7 on: 29 November 2017, 11:20 »
I never thought the soundaktor was a problem, but I've set my GTD to individual/eco engine noise and its remarkable how much noise the soundaktor makes even in normal mode.
I never used to understand why people used to moan about it and disconnect it, but its made my car much quieter which is only a good thing when you munch as many miles as I do. Noise is tiring, which isn't good for driver alertness.
Offline Jim_mk7.5
« Reply #8 on: 29 November 2017, 11:50 »
You have bought a hot hatch you know?! Were you expecting it to sound like a Prius? Turbocharged 4 cylinder engines are never going to be quiet in this type of car so I really have no idea what you were actually expecting to sound like.... It's a better sound than the one that uses the black pump.
NOW - 330e M Sport
Offline Watts
« Reply #9 on: 29 November 2017, 11:56 »
It'll definitely be the soundaktor. I unplugged mine but thought it too quiet so plugged it back in. I do still like it but am beginning to think I'd like to turn it down a bit but on mine you can't do that in individual and I'm not going to put the whole car in ECO mode :rolleyes:
Previously:
