Author Topic: Replace Rear Discs and Pads  (Read 6198 times)
Offline orcades
Re: Replace Rear Discs and Pads
« Reply #10 on: 29 October 2017, 09:38 »
Oops, just re read the e-brake bit, how stupid am I. I thought you meant some spray for the discs. Not sure why I thought that.
VW Golf GTI Performance Pack, Manual, 5Dr, Deep Black, Rear View Camera, Adaptive Chassis Control, Climate Windscreen, Park Assist, Winter Pack, Discover Nav Pro, Keyless Entry, Side Airbag System, High Beam Assist, Dynaudio. Ordered 26/08/2013, Collected 12/12/13
Offline golfdave
« Reply #11 on: 29 October 2017, 09:50 »
What does the MOT cert say?...if it is just "advisory" don't bother replacing until you get a Fail on them.
I had my car in for MOT & I said I'd get an advisory, & the MOT did come back with that & a price for the job, which I refused as not a "Fail".
Rears on the MK7 Golf are way over braked for what they do, so they will never get shiny & I have always had rears on my cars get scored & rusty....fronts is a different matter...fronts on the MK7 are underbraked...IMHO...
If you want to get new discs & pads get a set of plain ATE discs as these are made to very tight tolerances..& get their low dust ceramic?? pads...I have their grooved discs which work with their plain pads on the front..
PS I'm near to you & have legit VCDS  if you need some work doing..
Offline itavaltalainen
« Reply #12 on: 29 October 2017, 13:30 »
Braking heavy from 60 won't do sh!t. Mostly on the fronts.
Don't get VW to change them, they will most likely fit the same sh!t parts again. They use two suppliers, my second set (first replaced under warranty) seems to be better than first but that was only 5-10k miles ago.
I'd go down ATE aftermarket route.
Offline Finglonga
« Reply #13 on: 30 October 2017, 11:17 »
Yes it does, it cleans them up nicely and is the only time I have ever got them hot as the PP is way over braked at the front. Needs to be done every couple of months
Offline orcades
« Reply #14 on: 01 November 2017, 18:16 »
Apologies for delay in replying.
1) It was just an advisory re the rear brakes. Never thought too much about the aftermarket options, will look in to that.
2) Golfdave, I’d be interested in some VCDS Tweaks. In particular turning the engine sound thing off.
Thanks,
Offline golfdave
« Reply #15 on: 01 November 2017, 20:01 »
Thanks,
PM sent..
Offline orcades
« Reply #16 on: 02 November 2017, 04:48 »
Thanks golfdave,
Re ATE Discs and Pads, can somebody post a link to a set. I did Google it but there’s a bewildering choice.
There seems to be quite a selection of ATE Brake parts.
Offline golfdave
« Reply #17 on: 02 November 2017, 09:11 »
Thanks golfdave,
PP has bigger rear discs & fronts, basically you have the whole "R" brakes system...
ATE web cat
http://ows-cdn.tecdoc.net/ate/home.jsp?server=6&time=2/11/2017-8:54:31#0ffbc4419db666256d142510e74371a1
310mm x 22mm rear disc
http://ows-cdn.tecdoc.net/ate/home.jsp?server=6&time=2/11/2017-8:54:31#f2901cf42f9aa12734f0cff5867d18d0
ATE part no. 24.0122-0219.1
VW OEM number 1K0615601N ?? & PR code 1KJ & 1KY
Ceramic low dust pads ATE for same PR codes for rear.
http://ows-cdn.tecdoc.net/ate/home.jsp?server=6&time=2/11/2017-8:54:31#a30dbd76e954e86cf78735656453d75e
13.0470-7294.2
You might need to double check these but that's what I can find ATM..
Offline Bungleaio
« Reply #18 on: 02 November 2017, 21:31 »
Have you priced them up for TPS? I get all my bits from them and they are usually very good and are obviously genuine parts.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
