Author Topic: Replace Rear Discs and Pads  (Read 6188 times)
Offline orcades
« on: 27 October 2017, 10:49 »
Hello,
Appreciate there is a recent thread about sourcing discs and pads. I’m needing Discs and Pads soon, but I’d rather get them supplied and fitted. The VW fixed price deal is about £260 for front or rear discs and Pads.
Is there any other options out there. I’m based in Inverness,
Best Regards,
VW Golf GTI Performance Pack, Manual, 5Dr, Deep Black, Rear View Camera, Adaptive Chassis Control, Climate Windscreen, Park Assist, Winter Pack, Discover Nav Pro, Keyless Entry, Side Airbag System, High Beam Assist, Dynaudio. Ordered 26/08/2013, Collected 12/12/13
Offline Finglonga
Re: Replace Rear Discs and Pads
« Reply #1 on: 27 October 2017, 11:01 »
How have you worn out rear discs and pads? Christ they should last an eternity the amount they are used.
I would try to find a good independent if they need doing as dealers are always well over priced compared to them. It is a simple job and any garage will be able to do it.
Offline dereks
« Reply #2 on: 27 October 2017, 11:53 »
Problem is they don’t get used so they rust,get used,rust etc ends up scoring the discs.
Online Watts
« Reply #3 on: 27 October 2017, 11:58 »
Looking on Euro Car Parts, a replacement set (I selected Brembo, there were others a bit cheaper) came out at nearly £180 which makes the VW fitted price seem not unreasonable. There was a discount code though which brought the cost to under £110 - any local mobile mechanic would probably do both sides in an hour max.
Previously:
Offline fredgroves
« Reply #4 on: 27 October 2017, 12:42 »
Does the Mk7 tell you when you pads are shot?
The most common cause of needing new discs is running a pad worn down to the metal which scores the disk...
Offline orcades
« Reply #5 on: 27 October 2017, 12:52 »
Hi Watts,
Yeah good point re price. I had priced job at Halfords and PP GTI Vented rear discs and Pads are not cheap to replace. So for a bit more may as well go VWdealer route.
Think reason for a lot of wear on rear brakes is rust, the car sits for a month or more, so the discs get very rusty, and never quite get rid of the rust on rear discs.
I have a BMW Motorbike and had to replace rear disc at 7500 miles due to pitting with rust.
Offline orcades
« Reply #6 on: 27 October 2017, 13:09 »
I believe the Mk7 would have some means to indicate worn Pads. The car was recently in for a service so the pad thickness was checked then.
Offline Finglonga
« Reply #7 on: 28 October 2017, 11:35 »
A few heavy braking from 60mph (ish) should clear it up. You can use the e-brake but not at low speeds as it will lock the rear up.
Offline orcades
« Reply #8 on: 29 October 2017, 09:20 »
Unfortunately after nearly 4 years the rear discs are quite badly scored, the front is fine, lot of life left in Discs and Pads. Never heard of e-brake - I’ll Google it. Thanks
Offline fredgroves
« Reply #9 on: 29 October 2017, 09:23 »
E brake is the handbrake...
