Author Topic: Fault codes  (Read 10290 times)
Offline 2007GTI
Fault codes
« on: 29 September 2017, 18:11 »
So I only picked my second hand GTI up last week, and I just scanned it with OBDeleven and the following 3 fault codes have come up, I'm shocked, other that get it into the dealer, any advice?
Offline wantmygti
Re: Fault codes
« Reply #1 on: 29 September 2017, 18:20 »
I would wipe them all and rescan in a week. I bet they don't recur.
2017 GTi Clubsport arrived June 2017
2007 Shadow Blue GTi, sold on after 10 years ownership
Offline 2007GTI
Re: Fault codes
« Reply #2 on: 29 September 2017, 18:59 »
Thanks for the advice, I guess even if they reappear it won't matter that I cleared them
Offline golfdave
Re: Fault codes
« Reply #3 on: 29 September 2017, 20:05 »
One thing I don't like about OBD1 is that for two of those fault codes it does not state the date/time that it first occurred...& that info is in the control module...
The last one which did , was a fairly recent code...
Personally I would save those screen shots & print out & tell the dealer, cover your back as fault codes should not be there..even if it was an old one off fault they should check & wipe any before they sell on
Offline Finglonga
Re: Fault codes
« Reply #4 on: 30 September 2017, 11:10 »
Don't worry about them, fault codes pop up all the time. Unless you have a problem they are not worth worrying about. Dealers hate these diagnostic things as everyone when they buy them turns their car into a hypochondriac and bugs them about non issues.
Offline 2007GTI
Re: Fault codes
« Reply #5 on: 30 September 2017, 13:20 »
Thanks for all the replies.  I wiped all apart from engine codes and sent that one to dealer, just to see what they say.
Re: Fault codes
« Reply #6 on: 30 September 2017, 15:07 »
They'll probably say "stop using third party software in the ECU or we'll void your warranty!"  :laugh:
Offline 2007GTI
Re: Fault codes
« Reply #7 on: 30 September 2017, 18:18 »
Funny
Offline Booth11
Re: Fault codes
« Reply #8 on: 30 September 2017, 18:23 »
I've had a few fault codes come up with obdeleven then never again.  When you are scanning the car are you running the engine or just ignition on?  It can make a difference and running a scan without the engine running can throw codes that don't appear on a scan run with engine on.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline 2007GTI
Re: Fault codes
« Reply #9 on: 30 September 2017, 18:25 »
Thanks, I had the engine running.
