Author Topic: HI from notts  (Read 6148 times)
Offline daveyf37
HI from notts
« on: 24 September 2017, 08:54 »
Hi guys im a proud owner of a red 64 plate with pp loving the car had it nearly 2 years now but decided to trade it in for a brand new one which should hopefully pick up mid November.Does anybody on here know if there is an aftermarket exhaust system I can fit which wont void the warranty love the sound my 64 makes just wanna make the 67 sound better.many thanks.
Offline I wanted a GTi
Re: HI from notts
« Reply #1 on: 24 September 2017, 11:41 »
A cat back exhaust can't void your warranty.
Re: HI from notts
« Reply #2 on: 24 September 2017, 11:43 »
Congratulations (new car).  :smiley:
No there isn't (warranty friendly exhaust).
But the FL cars do seem to sound a bit fruitier than the older cars.
Maybe you should have bought a Clubsport which is fractionally noisier than a regular GTI, or at least they sound that way from inside and with the Sound Rattle-ulater turned off.
Or better still a Golf R with Performance Pack.
Now that would sound nice.
Re: HI from notts
« Reply #3 on: 24 September 2017, 11:46 »
How would an exhaust void the warranty?
Re: HI from notts
« Reply #4 on: 24 September 2017, 11:49 »
Depends on your dealer and what the problem is.
Re: HI from notts
« Reply #5 on: 24 September 2017, 14:02 »
Doesn't matter what the dealer thinks, I was told that a broken driveshaft wasn't covered because the car was mapped with a few other mods. Quick word with VW legal department to point out that they have to prove the modifications were completely the cause of the part/s failing. As they couldn't they had to cover the warranty.
Offline Finglonga
Re: HI from notts
« Reply #6 on: 25 September 2017, 09:05 »
The exhaust doesn't void any part of the warranty except the CAT and exhaust warranty for obvious reasons :grin:. I asked VW UK before fitting my Remus.
Offline daveyf37
Re: HI from notts
« Reply #7 on: 25 September 2017, 21:01 »
Thanks for the info guys can anyone recommend a good system.
Re: HI from notts
« Reply #8 on: 25 September 2017, 21:27 »
Don't discount getting one made rather than an off the shelf one.
Online Watts
Re: HI from notts
« Reply #9 on: 25 September 2017, 21:50 »
I'm sure I've read on here somewhere that the MK7.5 has an improved exhaust note so might be worth letting the car run in for a few months before commiting to replacing the system in case it does what you want as stock. If it still doesn't do what you want then I'd look through you tube for videos of various options to get an idea of what does it for you. I think you can remove the middle box and replace it with a straight pipe for instance, could be a good easy option and economical.
Previously:
