Author Topic: HI from notts  (Read 6149 times)
Offline I wanted a GTi
Re: HI from notts
« Reply #10 on: 25 September 2017, 23:39 »
I'm sure I've read on here somewhere that the MK7.5 has an improved exhaust note so might be worth letting the car run in for a few months before commiting to replacing the system in case it does what you want as stock. If it still doesn't do what you want then I'd look through you tube for videos of various options to get an idea of what does it for you. I think you can remove the middle box and replace it with a straight pipe for instance, could be a good easy option and economical.
64 plate.
Offline Mark V GTD
Re: HI from notts
« Reply #11 on: 26 September 2017, 08:16 »
No, its a brand new car  (7.5) - its replacing the 64 plate (see line one of post one.)
Re: HI from notts
« Reply #12 on: 26 September 2017, 10:39 »
Sorry, my mistake.
Offline daveyf37
Re: HI from notts
« Reply #13 on: 26 September 2017, 19:49 »
The new one isn't coming with the pp will that make a difference to the exhaust note.
Online Watts
Re: HI from notts
« Reply #14 on: 26 September 2017, 21:52 »
Shouldn't do, PP is logoed and bigger front brakes, vented rear discs, lsd and a bit more power, nothing that should affect the exhaust note.
Previously:
Offline daveyf37
Re: HI from notts
« Reply #15 on: 26 September 2017, 21:54 »
cheers for the info watts
Online Watts
Re: HI from notts
« Reply #16 on: 26 September 2017, 22:02 »
No problem :smiley: Main thing is to enjoy your new car, oh, and to post a few images when you pick it up :wink:
Previously:
Offline daveyf37
Re: HI from notts
« Reply #17 on: 27 September 2017, 14:51 »
yeah watts ill put some pics up no probs ill post some of my 64 aswell
Offline daveyf37
Re: HI from notts
« Reply #18 on: 27 September 2017, 16:15 »
How do I post pics
Online Watts
Re: HI from notts
« Reply #19 on: 27 September 2017, 17:15 »
You need to upload them to a hosting site then paste a code into your post. Since photobucket started charging, on the recommendation of a poster on here I started using postimage.org which is easy to use. Set up an account then click on upload keeping images the same size, once uploaded use the hotlink for forums. Do ask again if unsure :smiley:
Previously:
