Author Topic: Winter wheel fitment?  (Read 5915 times)
Offline CocoPops
« on: 07 September 2017, 19:34 »
I have a set of wheels (AudiQ3) and before I flog them and replace, will they fit the Mk7.5 GTI?
Wheel Size: 6,5Jx17 ET
Wheel offset [mm]: ET 33
Rim width: 6.5J
Bolt circle [mm]/number of bolts: 112/5
If they do fit, I only need to replace the tyres with some that match the original rolling radius of the 225/40/18 tyres.
2018 GTI Performance Pack DSG 5dr, Tornado Red, Leather, 18" Seville Wheels, DCC Suspension, Tints, RVC
2018 Lotus Elise Sport220
Previous : 1983 Mk1 Golf 1.1 & 2008 Mk5 Golf GTI Ed30
Offline phope
Re: Winter wheel fitment?
« Reply #1 on: 07 September 2017, 21:29 »
No, the wheels will stick out way too much from the arches with that offset
Golf Mk8 R order cancelled...awaiting company car instead
Tiguan 1.5 Elegance for the wife & dogs
Skoda 1.5 SEL cheap lease special
Offline Hebegeebee
« Reply #2 on: 08 September 2017, 01:32 »
According to willtheyfit.com they will fit, poking out nearly 10mm more than the standard 18" which is still ok but at 6.5" width you'll probably have to use 205/50/R17 sized tyres as 225 will likely be too wide for the rim.
Picked up 03/Nov/2017 - GTi-P, White silver, 5dr., Manual with extras
Offline I wanted a GTi
« Reply #3 on: 08 September 2017, 09:51 »
They will fit fine with the right tyres, something like a 205/50/17
Offline SRGTD
« Reply #4 on: 08 September 2017, 10:33 »
OP; as your Golf on order is the GTI Performance model with the larger brake disc and calliper assemblies, it's also worth checking that the design of the spokes on the Audi wheels aren't too thick front to back, so they'll clear the larger brake discs and calipers on your Golf.
And yes, you would need different tyres so the overall rolling radius of the Audi wheels with tyres fitted is the same as the Golf with 18" wheels and 225/40 R18 tyres fitted, otherwise you'll get a speedo reading error.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Wide
« Reply #5 on: 08 September 2017, 19:11 »
It is really tight with 17"   :grin:
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline CocoPops
« Reply #6 on: 24 November 2017, 20:58 »
« Last Edit: 25 November 2017, 11:36 by CocoPops »
« Reply #7 on: 26 November 2017, 11:35 »
^^^^ Yes but they'll look rubbish without spacers with that offset (which is an Audi A3 offset).
Offline mustard
  • Mk7 R
« Reply #8 on: 26 November 2017, 12:08 »
I have similar on mine as winter wheels, I use a 5mm spacer and they clear the calipers fine.
Offline CocoPops
« Reply #9 on: 26 November 2017, 12:37 »
Ok, so ideally... what should they be?
What are the OEM GTI wheels?
