Author Topic: Mirror tilt on reverse not working  (Read 14033 times)
Offline gti_travels
« on: 26 August 2017, 07:44 »
Morning. Has anyone had any luck setting up their passenger side mirror to dip when reversing? The function is enabled, but when trying to follow the set-up instructions detailed in the user guide the option to configure the amount of dip for each user profile is missing. Any help appreciated!
2017 5dr Indium Grey DSG GTI, 19" Santiago
Offline Wide
Re: Mirror tilt on reverse not working
« Reply #1 on: 26 August 2017, 07:50 »
I think i have the same problem, my mirror just tilt a little bit. Not enugh.. :sad:.
Can you adjust that?..
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline CS#433
« Reply #2 on: 26 August 2017, 08:39 »
You should be able to adjust it if it's the same as the MK7 to tilt fully down to see the kerb. Turn on ignition, put the mirror adjuster into L, put car in reverse and then adjust mirror knob to tilt mirror and then that it.
It is programmed to whatever ignition key you used to set it so if you swap keys a lot then you will need to set it up on both.
Oh and you may need to turn it on in the settings on the info unit.
Sounds like gti-travels is having more technical issues with it though but above is how to set it.
Offline Beezer
« Reply #3 on: 26 August 2017, 12:07 »
Also, for it to work I think you have to leave the little wing mirror dial on L.
I had this problem at first I always had mine set to 0.
Leaving it on L doesn't help with my OCD mind!  :angry:
Offline Watts
« Reply #4 on: 26 August 2017, 13:48 »
Exactly this and especially the second point!
Previously:
Offline Briggsy
« Reply #5 on: 27 August 2017, 07:37 »
The car has mirror tilt??
Offline SRGTD
« Reply #6 on: 27 August 2017, 07:53 »
Not the most exciting read, but always worth reading through the manual to discover those little surprise features!  :wink:
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline fredgroves
« Reply #7 on: 27 August 2017, 10:10 »
Black marker pen... Remove the markings on the twiddly knob. Problem solved :-)
Offline I wanted a GTi
« Reply #8 on: 27 August 2017, 13:04 »
I don't like the volume wheel not being centred but I don't have OCD.
I had a friend that took hours just to leave his house, he had OCD. He once said to me that people saying they have OCD when don't is no different than some with a headache saying they have a brain tumour when all they have is a headache.
You'll notice I said had, he couldn't handle his OCD.
Sorry for the rant but it is one of the few things that really winds me up.
Offline Briggsy
« Reply #9 on: 27 August 2017, 17:51 »
Well so it does, I might break the man code and read the manual to see what other goodies I'm missing out on.
