Author Topic: Clubsport S Cup 2 tyres - bespoke?  (Read 15765 times)
Offline WWCSS
« on: 10 June 2017, 17:45 »
I need to get a new rear tyre due to a puncture, and reading quite a few of the press releases from when the car came out, they all mention that the car is shod with bespoke Cup 2 tyres from Michelin.
Does anyone know if this is correct, or whether a standard Cup 2 tyre will do?
I have contacted Michelin UK, as VW don't even have the tyres available as a spare part - just said they can't help me..
2016 GTi Clubsport S Diamond Black Pearl (current)
2008 R32 5 Door DSG Diamond Black Pearl (current)
Offline scanesare
  • GTI Clubsport
Re: Clubsport S Cup 2 tyres - bespoke?
« Reply #1 on: 10 June 2017, 17:58 »
I have read most stuff relating to the CSS but not heard of bespoke to CSS tires before, any links to confirm this? I'm 99% sure it's the standard PSC2.
If I had to change tires on the CSS I would seriously consider the new Michelin Pilot Sport 4S which seems an excellent performer. Better than the old MPSS so closer to the PSC2 but with big improvements on the wet, economy and noise areas. The PSC2 does not make much sense on any car that is not tracked often or at least enjoy very good, dry tarmac on a regular basis, I'd imagine it's even worse on the average UK roads + weather combo.
Offline WWCSS
« Reply #2 on: 11 June 2017, 00:18 »
Here's one article mentioning bespoke Cup 2's:
http://www.evo.co.uk/volkswagen/golf-gti-clubsport/17816/volkswagen-golf-gti-clubsport-s-review-updated-with-uk-driving
I wonder if it's just marketing bs..
« Reply #3 on: 11 June 2017, 10:49 »
There was a hell of a lot of marketing bs surrounding the Clubsports in both guises. I'm sure there would have been a note of some sort within the car literature that you get if the tyres were bespoke but the easiest thing to do is check the exact writing on the tyre sidewall. Just like Porsches with their N spec (which the CS might have borrowed) if there is something bespoke about them then the tyres will tell you in code.
Offline I wanted a GTi
« Reply #4 on: 11 June 2017, 11:04 »
If you have a big monitor you might be able to read what it says on mine.
Offline scanesare
  • GTI Clubsport
« Reply #5 on: 11 June 2017, 18:37 »
Not marketing BS, this is only an online article of a car magazine (not related to VW) and while EVO are pretty respectable in general, their online articles often suffer from too much post-upload editing and confusing info. I have noticed they change articles but adding pieces of text after a while only to make them appear more recent. That "bespoke" mention is something that has probably slipped there. Other than I have never heard about Clubsport bespoke tires, in the hot-hatch group test between CSS, Cupra, Focus RS and Type-R in magazine form which is much more looked after for typos and accuracy (EVO 227) I read:
"...to level the playing field all four cars wear the same rubber. The MPSC2 is standard-fit on the CSS and an optional extra on both the Focus RS and Cupra 290 but we've had to fit them ourselves to the Type R...". They would have mentioned of a bespoke tire there unless the Focus is also coming with bespoke to CSS tires as an option, probably not.
« Last Edit: 11 June 2017, 18:41 by scanesare »
Offline WWCSS
« Reply #6 on: 12 June 2017, 14:05 »
I have received confirmation from Michelin:
None of our MICHELIN Sport Cup2 tyres are homologated specifically for VW vehicles.
So it looks like a standard replacement will do.
Offline wigit
« Reply #7 on: 12 June 2017, 15:59 »
My experience of SC2s were when i had a puncture, whilst the puncture was repairable in the 300m or so to a come to a halt the side wall was toast
I have been amazed how reliant these were to abuse on track and how well they cleaned up
« Reply #8 on: 12 June 2017, 17:27 »
I think they are great but only if you either don't use the car in cold conditions or use winter wheels.
Offline mkviken
« Reply #9 on: 29 September 2017, 10:18 »
Wht pressure does everyone run in the cup2?
Door sticker says 38 which is crazy
Michelin replied to me and said follow manufacturer guide on road but on track 34psi
I currently have them at 34 front and rear cold and feels ok
Golf GTI 7.5 230 white silver
