Author Topic: Fuel pump query  (Read 11237 times)
Offline philstar
  • ...life is all about creating memories...
Fuel pump query
« on: 03 June 2017, 17:12 »
My golf has been stood for a year, I have just done a load of welding on it for MOT and I started it today to find a big leak coming from the fuel pump underneath:
https://goo.gl/photos/WvDWnKXU56qSezcT7
https://goo.gl/photos/t2Qw1zDgkcV6iMaKA
Does this look like your bog standard worn out o-ring scenario, and is it the right pump for my car? I have an 88 small bumper 16v k-jetronic.
Is it ok to remove it or do I have to de-pressurise the system first somehow?
Are genuine spare parts still available for this fuel pump?
1988 Atlas Grey VW Golf Mk2 16V GTi [F748 FGT]
Rebuilt: fuel pump housing | suspension | gear linkage | aluminium radiator
Offline lemski
  • 16v
Re: Fuel pump query
« Reply #1 on: 03 June 2017, 22:01 »
You could probally get a seal for it from maybe tps or vw heritage.
Looks like the kjet style pump
Offline philstar
Re: Fuel pump query
« Reply #2 on: 04 June 2017, 18:42 »
Well I tried to remove the fuel pump, but the philips head screw above the pump had been rounded.
So I tried to take the combined filter-pump-swirlpot mechanism off, but the mounts all broke.
So I took everything off including the mount. Why is it made of plastic?! The swirl pot housing is broken. The swirl pot is covered in 30 years of rust. I know the pump works fine but the housing must have distorted to cause the leak because the o-ring is in great shape. Perhaps I generated too much heat near it when I was welding. Another great Sunday.
I just hope I can get good quality new parts...
Offline lemski
  • 16v
Re: Fuel pump query
« Reply #3 on: 04 June 2017, 22:43 »
You wont fi d the housing. They are rare. Second hand demand high money aswell. Maybe yours can be reheated and saved or sonething.
Offline philstar
Re: Fuel pump query
« Reply #4 on: 05 June 2017, 10:45 »
OK here's the situation. The pump retaining collar shows a gap at the base when joined to the housing:
https://goo.gl/photos/TZ8o4R6yzauNXQCC9
A new seal might pad it out and a bit and stop the leak but I'm not confident.
The accumulator has a pinhole at the base:
https://goo.gl/photos/d5WvQ3Sa1iYvaSNK7
I'm sure I can weld this up?
The union nuts are in a right old state:
https://goo.gl/photos/6MZft1VcRqiKb4KfA
I know goodridge sell a stainless steel set of these for £100
Is there an alternative option to spending close to £200 on a secondhand unit? It may sound silly but i'd rather spend £300-£400 on a modern conversion than risk £200 on original second hand items that may fail soon, or not even work on the first place.
Has anybody come up with an alternative solution? Does a system of another car work? My bracket is in good order so I can build a custom mount myself.
Struggling here, I've spent weeks welding and prepping the car so I can't give up now!
Offline philstar
Re: Fuel pump query
« Reply #5 on: 05 June 2017, 14:46 »
OK have had the accumulator brazed by magic Malc at TTP Performance in Bromsgrove, and have ordered a new fuel pump seal from THE ONLY supplier I can find, an eBay trader in Athens:
http://www.ebay.co.uk/itm/331623858599
part number is N 903 124 02 (for later MK2 golfs I believe the part number is N 90262802 see here: http://www.golfgtiforum.co.uk/index.php?topic=117876.0)
All I can do now is wait, and prey. Unless someone has experience of another solution which I may still yet need!
Offline philstar
Re: Fuel pump query
« Reply #6 on: 05 June 2017, 14:49 »
rubjonny has posted on the clubgti forum:
http://clubgti.com/showthread.php?270543-Golf-gti-mk2-16v-external-fuel-pump-housing
"yes use an inline kjet pump such as mk1 gti, plus an external fuel reservoir. the post-84 mk1 cabrio and scirocco as well as all g40 shape polo have one that is perfect. but any decent 4 outlet reservoir would do you. the main trouble is getting it all under there as you have pump, filter, reservoir and accumulator. the mk3 has a fuel filter carrier which might be handy to start with, or use the old mk2 metal pump carrier to fab something up"
Offline philstar
Re: Fuel pump query
« Reply #7 on: 05 June 2017, 17:00 »
For £120 a complete set of stainless steel braided hoses can be bought, made by HEL:
http://auto.helperformance.com/volkswagen-golf-mk2-gti-16v-k-jet-1984-1992
It's either that or buy the two that are damaged individually for around £50-£60.
Offline lemski
  • 16v
Re: Fuel pump query
« Reply #8 on: 05 June 2017, 21:01 »
You can ditch k-jet and change management allowing you to then change to mk3 fuel tank in intank pump.
You can change the pump to a high pressure pump and use the accumilator still.
Or you can buy 2 damaged pumps and make a good one out of both.
Peraonally ide get an external high pressure pump in line and keep the accumilator
Offline philstar
Re: Fuel pump query
« Reply #9 on: 11 June 2017, 16:14 »
Cheers Lemski do you know where I can find the specification for the pump I would need if I choose to run a new external one? I am just waiting for the seal to arrive from Athens in the hope of saving the original setup but if it fails my next logical choice is to replace the pump.
