cool, gsf sell the housing and its gen vag
18370B FUEL PUMP HOUSING G2 16V 2/86 >10/91 43.00
MMWK853/1 FUEL FILTER G2 1.8 16V 86>89 10.90
MMWK834/1 FUEL FILTER-BQ G2 1.8 16V 8/89> 8.40
rest of the bits are VAG only. take it from someone who has done this twice in the past, you dont want to mess about with 2nd hand housings, or take a chance on them rubber mounts, they always rip in half
N 90262802 - fuel pump seal - 3.9€
N 10404701 - fuel pump screw - 0.24€ x3
191201256 - rubber mount - 4.1€ x4
you'll also need 8 M6 washers & nuts for the mounts, plus a 20mm M6 bolt, nut & 2 washers either side for the pump/accumulator pinch clamps if the old ones dont play nice.
Tip for you, lift up the boot carpet and take out the round metal plate, under here you'll find the lift pump. disconnect the 2 fuel lines here or all the fuel will drain out the tank from capilery action, been there got the t shirt
