Author Topic: Start/stop deactivate MK7.5?  (Read 22171 times)
Offline Wide
« on: 27 May 2017, 18:11 »
When i connect my GTI, the OBDeleven say a i have a Mk7 Club Sport :)
I have the new facelift Mk7.5 so many of the apps don`t work.
When i search in the App a can find my facelift  car, but when i connect it is a Club Sport :)
What are i doing wrong? :)
Video with the problem  :laugh:
https://www.youtube.com/watch?v=F3UJfH03uAI&feature=youtu.be
« Last Edit: 27 June 2017, 06:47 by Wide »
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline I wanted a GTi
There was an update on the OBDeleven a while back, I thought mine was showing as a clubsport because I had used my sisters clubsport but when I thought about it I had used it on my car after that and it was showing my car. It was after this that it started showing my car a a white 3 door clubsport and not a 5 door.
Are you using the pro version or not? I have the pro version and I only use the long coding.
Offline Booth11
As above there's been a few updates on the obdeleven app, one very recently, so make sure your app is up to date.  I used mine a couple of days ago and had to do the update first (I have pro version) then had to reselect my car again.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
What's the engine code on the PP 7.5 GTI's? Or more specifically the turbo part number.
Have VW put a de-tuned R engine in the 7.5 PP? That might sound fanciful but the non PP gets a six speed DSG and the PP gets a 7 speed so maybe VW have just done a parts rationalisation. Stranger things have happened.
Offline Wide
Hmm, ok. I am using the pro version. Long coding?, you don´t use the apps?
I have the latest app, but it don´t help.. :(
Offline Wide
Hmm, thats sounds strange :)
Where can i engine code and turbo part number?.. :sad:
Offline clubsport
My GTi PP comes up as a CS on OBD Pro.
This is when I enter the vin number to identify the car.
I think the reason is the PP & CS both share the tricky diff that OBD11 has apps for which wouldn't be the case on the regular GTi.
This hasn't caused me any problems.
Offline Wide
Aha.. You maybe right! :)
But i have 2 problem!, i Want to shut the start/stop of. But thant dont work..:(
Then i want to hace the "scandinavian" DRL backlights. We don´t have scandinavian taillight any more.....the EU :(
Does that 2 apps för you? :)
Have a good read through http://obdeleven.proboards.com/board/81/mk7 and learn the long coding. It is really easy when you work your way around it.
Offline clubsport
OBD11 has updated a few times lately.
Today, I cleared the cars in my "garage", the new format asks for the vehicle Vin to be entered.
I entered this for my GTi PP and it came up in the OBD11 as a a GTi Clubsport.
 (Note; This has been done/updated since my post this morning!)
Looking at the apps available now on OBD11 Pro...
I have available  Scandanavian DRL's and deactivate stop/start which I have used.
There is also diff setting option of XDS interaction.
There is nothing I can't amend that was previously available to me before the update.
