Author Topic: Start/stop deactivate MK7.5?  (Read 22172 times)
Offline Wide
OBD11 has updated a few times lately.
Today, I cleared the cars in my "garage", the new format asks for the vehicle Vin to be entered.
I entered this for my GTi PP and it came up in the OBD11 as a a GTi Clubsport.
 (Note; This has been done/updated since my post this morning!)
Looking at the apps available now on OBD11 Pro...
I have available  Scandanavian DRL's and deactivate stop/start which I have used.
There is also diff setting option of XDS interaction.
There is nothing I can't amend that was previously available to me before the update.
That you fo your support !. But i have the latest app, and it says it don“t support Start/stop and Scandinavian taillights :(
Maybe have to wait for some more update..
My Youtube Channel ** MK8 R and MK7.5 GTI PP**
https://www.youtube.com/channel/UCOQb17Kro9L-iuT91cKxsjA
And My INSTAGRAM FaceliftGT
https://www.instagram.com/p/CHKNpaNHog_/
Offline I wanted a GTi
Any other people with facelift cars and OBDeleven that have used long coding and had problems?
Offline andy28
Sorry for the delay, I'm away at the min so not been on here quite as much!
I've used OBDeleven Pro on my GTI Facelift (non-PP) and whilst the one touch apps didn't work (said "not supported"), I have turned on Scandinavian DRLs the long way. I'm still away for a while but I've copied the following from my OBDeleven history and memory...
Click the button on the bottom right of your screen when your car is connected. It's a circle with three horizontal lines.
Go into Control Unit (09) Central Electrics.
Select Adaptations
Select "Aussenlicht_Front"
Select "Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht"
Change "inactive" to "active"
That should do it for you. If not, happy to do some screenshots when I'm back.
As for wrongly identifying your car, I think mine did come up as a clubsport image at first but now it definitely shows a GTI with Parker alloys!
GTI Clubsport Edition 40
#301 and then #190
Offline Wide
Select Adaptations
Great!!, thank you very much! I will try this tonight!. I take som screenshots if not work!
Thanks again  :smiley:
Offline Wide
Select Adaptations
IT WORKED!!!, and the car is not a CS longer when i put in the WIN nr :)
I owe you a beer!, if you come to Sweden ;)
I still have problem with the start/stop, someone with a solution for that? :)
Offline andy28
Excellent news, I'll let you know when I'm coming to Sweden to collect my beer ;-)
I've not tried anything with start-stop but will have a look to see what I can find.
#301 and then #190
Offline Wide
No time yet?. Someone else? :)
I H**te the Start/stop.. :grin: :grin:
Offline clubsport
Wide, I have sent you a personal message with assistance......
Offline Booth11
Is it the long coding you want?
Disable stop/start
1) Select Control unit 19
2) Select Adaptation
3) Select Stop start limit voltage
4) Change value to 12 (default is 7.4)
5) Press the green tick to confirm
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Wide
Yes thank you! :)
